Old 07-19-2005, 06:40 PM   #1
tomatocity
tomatocity's Avatar
Flip Kit lowering for a leaf rearend
Finally decided to use a Flip Kit to lower my truck 5" in the rear. This seems to be the most economical barring any unforseen issues. Here are a couple of questions:
-Will the frame need to be C-notch'd?
-What is the best Flip Kit?
-Do I really need a Flip Kit or can I use two new extended spring perch's?
-What are the flaws to lowering using a Flip Kit?
-Will I need shock extender brackets?
-Can I remove the bottom leaf (flat leaf)(five leaf spring) without a problem?
-Are there any other things to be concerned with?
I plan on lowering the rear first. Then I want to lower the front to match the rear using drop spindles and lowering springs if needed. Any suggestions or criticisms are appreciated. Thanks.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-19-2005, 10:32 PM   #2
bagged91
Out draggin'
bagged91's Avatar
You should have posted this on the Suspension board.... Should be some good answers already over there...Search key is back
91 GMC Xcab LB-Bags/bd/caddy clip SOLD
72 C10 Cheyenne Super LWB SOLD
92 GMC K1500 Burb
72 C10 Burb (ex. Cheesewagon)SOLD
72 C20 Burb parts truck
71 C10 Burb "project"
bagged91 is offline   Reply With Quote
Old 07-20-2005, 02:09 AM   #3
tomatocity
tomatocity's Avatar
thanks. After I posted it I realized it was on the wrong board. I asked Josh to move it. thanks again.
Old 07-20-2005, 02:14 PM   #4
drink2mny
drink2mny's Avatar
Your wish is my command.....
Support The Board
drink2mny is offline   Reply With Quote
