07-19-2005, 09:11 PM | #1 |
Got Horsepower?
broken bolt
i broke the pinion shaft bolt in my differential right at the end of the threads. what is the easiest way to remove the pin part of it?
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
07-19-2005, 10:12 PM | #2 |
yeah good luck. anytime ive broke em ive just got another full rearend and bolted the whole thing in.
07-20-2005, 02:06 AM | #3 |
Got Horsepower?
this is the axle that i just bought to replace the one that i destroyed so replacing it is not an option. the axles for the coil spring suspensions are kind hard to find where i live and i only found 2 that were decent and the other one is half burried in the dirt. i'm going to try to drill it out tomorrow
07-20-2005, 03:26 AM | #4 |
~Rest In Peace~
i think that bolt wont be easy to drill out if i remeber right i tried a easy out once it took for ever to drill a small hole i end up heating the bolt on the carrier and chiesled the rest out .oh i chiesed a small line across the bolt and got a screwdrive on the end and turned out
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
