Old 07-20-2005, 12:51 AM   #1
locab36
locab36's Avatar
Tach question 6 cyl or 8 cyl.........
I just put a tach dash in my 69 short step. Hooked it all up and everything works. Problem is the tach responds like its a 6 cyl tach? I can burry it (5k) w/ little effort. It just swings too easily. I tried to find the search but couldn't, then tried FAQ but didn't see anything there either. Is there a 6cyl 8cyl switch on the factory tach? I saw a small hole just above the coil/+ wire hook-ups. Just wondering if that is where you would switch it like many other tachs? Any help.
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 07-20-2005, 01:21 AM   #2
71swb4x4
71swb4x4's Avatar
You can fine tune it with that hole. I think you use a screwdriver, but it's been a while since I have had one apart. There 'should' slao be an 8 or a 6 stamped on teh back of the tach housing. Sometimes you won't find one though. You can try to adjust it and see if you can get it close. It may never be right on, these things aren't very accurate to begin with.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-20-2005, 01:51 AM   #3
SERE
"AIRBORNE"
SERE's Avatar
tach dash
I have adjusted two of them now. It is hit and miss. I used a rpm caculator I found on google and wrote down RPM at 55 60 65 70, Then went for a drive with my GPS on the dash. I was able to figure out my speedometer convsion I needed and if the tach was reading accuratly. I turned that dial at an idle and got it close. Then repeated the process. It worked for me. I have never found it in any manuals, I found the info on this board last year.
Good Luck!
Steve
69 GMC 2500 4X4 long stepside 454 BB
SERE is offline   Reply With Quote
Old 07-20-2005, 12:00 PM   #4
ckhd
ckhd's Avatar
I had to adjust mine. Used th little hole in the back & a screwdriver.
I hooked up a sun tach in parallel with the factory tach, and adjusted and adjusted and adjusted. Make sure when you're done adjusting that they match throughout the RPM range. If it doesn't, adjust at a different RPM. Took me probably 5-10 minutes of adjusting before they would match throughout the rpm range.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 07-20-2005, 12:39 PM   #5
locab36
locab36's Avatar
I have to get a new printed circut as all of my dash lights don't have power. I will try adjusting using the parallel method. Question, are the aftermarket tachs sold to retrofit any more accurate?
John
Locab36
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
