Adding Power Breaks?
I was just wondering how easy/hard it is to add power brakes to a 72 C-10. The stiff pedal manual brakes aren't bad, but power brakes would make driving all that much nicer. What parts would I need, and about how much would it cost. Is it worth the effort? Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
blood type; Retumbo
check www.napaonline.com or your local NAPA store for a "loaded" booster.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
I just installed the "Grand Slam" kit from Golden State Truck Parts. It cost about $1399 but includes everything you need to convert to power disk brakes in the front and lower your ride if you wish. It even comes with shocks and springs for front and rear. If you already have disk brakes then you just need the power brake booster. I have seen them for around $300. Power brakes are well worth the expense.
I bought the complete setup off a donor truck. It was a pretty easy swap. I'm glad I did it. Probably not as good as a more modern setup but better than the non-power brakes of the day.
1969 GMC 3/4 Ton Long Bed Fleetside 350, 4 speed manual, P/S, P/B, Edelbrock 1406 Carb Beaverton / Portland Oregon |
I switched over from manual drums all around to power and put discs up front. There is a world of difference. Makes it a lot less sketchy to drive in heavy stop and go traffic.
Still Green but learning
I have a 71 with Manual Discs up front, when I look at the FAQ it looks like all he did was change the rod, add the booster, hook it up for vaccume and go. Does this mean that I do not have to change the MC or add a proportioning valve? is all this all ready to go because it has discs already?
thanks
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
Watch out for your cornhole !
![]() Join Date: Jun 2003
That is correct. Just unbolt the master cylinder from the firewall and pull it away some. Then install the booster, brackets, and push rod. Now, bolt the master cylinder onto the booster. No need to change the master cylinder or anything else. No need to even open a brake line or bleed them when you're done.
It's a good easy swap. Figure on 2 hours max. Getting the new rod bolted to the pedal under the dash requires some serious laying on your back under the dash. Around here, a rebuilt booster sell for about 80 bucks at a parts store. You will still need the brackets and rod though, so it's best to buy a whole assembly used somewhere and turn in the booster for a core and re-use the brackets and such. I usually just post a "want to buy power booster" ad in the parts board when I need one. Last one I bought was 50 bucks total. The 80 for the rebuilt booster brought the grand total up to 130 bucks. Money well spent for sure.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 07-21-2005 at 04:53 PM. |
#9 | |
You don't need to convert to disc brakes. I did my swap on a 3/4 ton truck with all drums.
Scott
Designated A-hole!
I'm also running 4 wheel power drums.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
What vehicle would I look on for a booster, rod and bracket? Does it have to be off a 67-72 pickup, or is there other vehicles it could come off too?
#13 |
The 73's and above have a different bracket. So your better off with one off a 67-72 pickup. Ask in the parts forum, Im sure somebodys got one...
#14 |
What is involved when going from 3-on-the-tree to a auto on a 71. I know it already has disc brakes, but what about the pedal assembly? I have a auto column, how much else is invloved. Those power brake boosters are sure large enough, it seems like they overpower the whole engine compartment.
Richard Dobson |
