07-21-2005, 06:49 AM | #1 |
Turn signal help.
Hey folks, I'm at work so I hoping to figure this out before I go home.
Coming to work today the turn signal on dash just showed "on" no blinky blinky when I used the signal. No problem I think. I just figured I blew a bulb. Well, I check the other direction nothing there. HMMM. I pulled into the lot and I have both front lights when I use the turn signal I cannot see the rears. I put on the lights all seems good. But still no turn signals. The rear lights are on but no blinking. I can't see if my brake lights are working (I couldn't find anything to wedge the brakes on.) So, I have good lights up front and no lights in rear when I use the turn signal. But Have lights all around when I turn on the lights. Status of lights when I brake is unknown. Any thoughts??? Is it the the can on the fuse block. Something else?? Brake light fuse is good. bob
1986 C10 Scottsdale 5.3, TH400 |
07-21-2005, 07:18 AM | #2 |
sounds like you had a common ground for the to back lights came loose...
07-21-2005, 07:54 AM | #3 |
were should I start looking?
