Old 07-21-2005, 09:51 AM   #1
rusted75 half ton
More trusty Less rusty
rusted75 half ton's Avatar
Exclamation Quick ? about 70's vs 80's truck beds
There are a couple of beds for sale locally,my current one is a 73-79?or80?(the round fuel fill hole)question is if I get an 80's bed with the fuel filler doors will it fit without changing the filler neck?anything else to worry about?Or is it a bolt in?
rusted75 half ton is offline   Reply With Quote
Old 07-21-2005, 09:57 AM   #2
bodydropped
u might have to shorten it because i had to when i went froma 78 bed to a 85 bed
bodydropped is offline   Reply With Quote
Old 07-21-2005, 10:17 AM   #3
rusted75 half ton
Thanks for the quick reply,how did you shorten them just cut them?I guess if worse came to worse I could pull some filler necks from the junkyard.
Old 07-21-2005, 10:32 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The size of the hoses are different in the later models (smaller), therefore the filler neck is smaller. The tank is on the opposite side if you are going from pre-78 to post 78. If you have dual tanks then you only have to worry about the differnt size hose.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-21-2005, 11:51 AM   #5
dswancutt
I am sure that 81 was the first year for the drivers side single tank. All of the 3 - 79's that my uncle and myself own are passenger side single tanks.
78 was the last year of the exposed cap.
Doug
dswancutt is offline   Reply With Quote
Old 07-21-2005, 11:52 AM   #6
bodydropped
i got a pass tank and my new bed was a dual tank
Old 07-21-2005, 01:25 PM   #7
rusted75 half ton
So would I need to get different tanks also or just hoses?by the way I have duals and the bed for sale is dual.
Old 07-21-2005, 03:14 PM   #8
Captkaos
Captkaos's Avatar
Doug
I was thinking and typing at the same time. You are correct. 78 was the last year for exposed caps, and '81 they swapped to the drivers side.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
