96 Blazer Rims fit a 72 GMC 1500?
Need some help here: I have heard that the bolt pattern on my 71 GMC 1500 is 5 x 5. I am looking at some rims from a 1996 Blazer, they have 5 lugs: will they bolt on correctly? These rims also were put on a 1989 Jimmy, but several tire shops could not tell me if they will fit correctly on my 71 GMC.
I need some new shoes on my truck, please help asap!! THanks! |
BigBlockBobby
Measure from the outside edge of one bolt across to the third bolt centerline. It should measure 5" exactly to fit your 71 truck.
Bob |
MOVE OVER
they were probably talking about the offset of the wheel? will it rub the inner fenders or tierods? I know the S-10 blazers and Jimmys will not work, even if they are 5 lugs... take one home and try it on...
No matter where you are..... There you are... Buckaroo Banzi |
Nope it will rub the control arm and plus you will have to have the center hole bored.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
#5 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
I have a 72 GMC C-1500 with 5X5 bolt pattern. I used the Rims from a 97 Chevy 350, and they fit perfect with no problems. I can post pic's later if you want.
Tank |
For the first 3 months I drove my 69 GMC last fall I carried a newer style wheel and tire for a spare, thinking it would work. Well the truth was revealed one day about 2 miles from home when me, my wife and 5 yr old son had a flat. I tried to put the spare on (right rear) and the tire started touching the inner fender well before the lugs even got close to tightened. Lucky me that we were only 2 miles from home and I had to hitch a ride home and get her dad to take me back with another spare. I would check the backspacing as well as the bolt pattern to be safe.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!! ![]() ![]() |
![]() ![]() Join Date: Jul 2002
Wheels from the 88-98 years trucks will vary on the fit. Some of the Aluminum wheels will not fit because of offset problems. I have a set of the SS chrome slots (15x7) and they fit the 71/72 5x5 just fine. The six lug wheels are normally the ones you will start running into problems with because of the offset and center hole.
