Old 07-21-2005, 03:22 PM   #1
chevman-67
chevman-67's Avatar
THM 350 trans problems!
anyone got any ideas whats wrong with this thing ,its a thm-350 in a 79 chev 1/2 ton 4x4.It has park ,reverse,neutral,1st,2nd,BUT NO 3rd it will not shift into 3rd gear at all fluid is full nice and cleen.Can it be a modulator prob?Govenor prob?any ideas will be a help.
gm's are #1
1967 chevrolet short step
1988 chev 4x4 1/2 ton
1989 gmc 1/2 ton
1991 chev 1/2 ton 4x4
1993 Jeep grand cherokee 4x4
And yes a 94 Ford Mustang.
chevman-67 is offline   Reply With Quote
Old 07-22-2005, 10:04 PM   #2
chevman-67
chevman-67's Avatar
anyone have a idea???
gm's are #1
1989 gmc 1/2 ton
Old 07-26-2005, 08:15 PM   #3
dons454s
dons454s's Avatar
It could be something wrong with e kick down something holding it tight ???
dons454s is offline   Reply With Quote
Old 07-26-2005, 08:44 PM   #4
jermasaurus
jermasaurus's Avatar
Thats what mine did about two days before it lost everything.
Pull the governor out and see if the valve moves back and forth when you move the weights. But if it only stays out of 3rd, the governor is not likely the cause.
-Jeremy
jermasaurus is offline   Reply With Quote
Old 07-28-2005, 10:53 AM   #5
chevman-67
chevman-67's Avatar
thanx guys anything is a try and better than pulling this tranny and yes only 3rd is gone.
gm's are #1
1989 gmc 1/2 ton
Old 07-29-2005, 07:31 AM   #6
the baron
the baron's Avatar
Hi ,
I got sometimes the same problem on my 1977 Impala ( 250ci / TH350 ) ...
while driving , put your speed selector from D to N & back to D , and see if the 3d speed engages ...
if yes , change your oil bath & filter , it could solve the problem , it did for me anyway...
seems strange , huh ?
have no idea where it comes from , sometimes I just have to play with that selector a little ( a little bit up ) , and the third speed engages , I must have a link & rod problem too ...
greetz
the Baron
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 08-01-2005, 02:18 AM   #7
iceman7329
iceman7329's Avatar
it needs a complete rebuild, only way to fix it normally.
iceman7329 is offline   Reply With Quote
