07-21-2005, 04:41 PM | #1 |
It's Done When It Runs!!
350 Oil Pressure
For you guys with a 350. What kind of oil pressure are you guys running at idle when warm? I am running about 20 psi. It goes up the more I am in the gas up to about 60 or 70. Idle seems a little low to me. Thanks in advance
Or Give Me DEATH |
07-21-2005, 04:44 PM | #2 |
Watch out for your cornhole !
GM's guideline is 10 psi per 1000 rpm. So, at an 800 rpm idle, 8 psi is minimum. 20 is plenty at a hot idle.
07-21-2005, 04:50 PM | #3 |
Cool, thanks, I thought I read that somewhere, but I thought I would ask the experts to be sure.
Or Give Me DEATH |
07-22-2005, 01:29 AM | #4 |
Having issues
at idle, flow is what counts. You could have zero PSI and still be OK, as long as oil is flowing. (tho have a seriously worn engine)
