Old 07-21-2005, 05:35 PM   #1
skokie
skokie's Avatar
8 or 6 3/4 inch balancer
I was told that the 6 3/4 balancers are the for small blocks and the 8's are use on big blocks however I have seen 8s on small blocks so heres the quesitons. Does it matter which one you use? Do you have to do anything special to use a 8 on a small block?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-21-2005, 05:39 PM   #2
pjmoreland
pjmoreland's Avatar
The timing pointer might be an issue. There could be interference.
pjmoreland is offline   Reply With Quote
Old 07-21-2005, 05:42 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Both sizes work on the sbc. My truck, with the 300 hp 350, had a factory 8" balancer on it. The bigger balancer is supposed to do a better job of damping. I switched mine out for a 6-3/4" Streetdampr, which should be better than an old 8" with dried-out rubber.
You will need a different timing pointer. I got an adjustable and set it after degreeing the cam.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-21-2005, 05:46 PM   #4
pjmoreland
pjmoreland's Avatar
If you are in need of a 6 3/4" balancer, I've got one that is practically new that you can have for free. I tried selling it a few months ago, but there were no takers. I'll be in Mountain View on Monday and Tuesday.
Old 07-21-2005, 06:24 PM   #5
skokie
skokie's Avatar
Pjmoreland. I already have a new one on the 350 just curious what the differnece was. Thanks for the offer though.
68 build thread
Old 07-21-2005, 06:54 PM   #6
tnblazerk5
User #12137
tnblazerk5's Avatar
not to steal the tread but i got a ? what size came on a 327 ? i have got small thin one on there ,iwas wondering if a bigger one would fit and could i keep the same pullys and everything line up ?
tnblazerk5 is offline   Reply With Quote
