Old 07-21-2005, 11:12 PM   #1
72GMC51
72GMC51
72GMC51's Avatar
uneven suspension
All right, I rebuilt the rear end new Eaton posi, left the 4:11 in, put new gas shocks, clean and painted track bar and trailering arms and installed new bushings, a sway bar, installed new 3" drop springs, brakes etc. The problem is the drives side at the rear wheel well is 31' the pass side is 32" ??????????????. Double check everything can't find the one inch not the floor, tire space is off the one inch also, it is in the suspention, any ideas.
JC
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10.
Are they ever really finished
72GMC51 is offline   Reply With Quote
Old 07-22-2005, 12:52 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Have you measured the floor to frame or the body? Frame will tell you more, especially near the spring attach points. Body can be off in relation to the frame.
If it's coil springs are the coils seated? Have you driven the truck, helping get things seated? When I did the spring change on mine, it all looked good until I drove it around the block. One of the coils had not been in right and rotated.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-22-2005, 02:24 AM   #3
tomatocity
tomatocity's Avatar
*Check the coil springs to see if they are seated correctly
*Make sure the rear swaybar is not binding. Release the endlinks.
*Make sure the panhard bar is not binding.
*Did you unbolt the bed at anytime?
Basically check anything you added or changed.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-22-2005, 07:41 AM   #4
Gray Ghost
Gray Ghost's Avatar
I noticed the 'new' S-10 my wife bought was like that...3/4" lower on the drivers side...so's my C-20 and so's my Elky...each a little lower on the driver's side. I'd be willin' to bet it's normal since there's someone on the driver's side 100% of the time the truck is driven and the passenger side is filled less than half that time.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-22-2005, 09:07 AM   #5
68 50th
68 50th's Avatar
My 71 C20 was a about 1/2-3/4 lower on the passenger side in the rear.
Checked everything, I even took out both leaf spring packs and changed side for them but the truck still sat a little lower on pass side.
I ended up putting shims between the frame and the bed crossmembers to get it straight.
Mats..
1971 Cheyenne Super Custom Camper 475CBB/TH400/AC
1992 Silverado Sport Truck
1988 Silverado 2500 Ext Longbed 4x4
2001 GMC Sierra SLT 4x4
1990 Chevrolet K3500
1965 Pontiac Grand Prix
1980 Z 28 350/4-speed/AC/T-top
1980 Camaro Coupe V6/3-speed
1979 Buick Century Wagon
68 50th is offline   Reply With Quote
