Old 07-22-2005, 01:03 AM   #1
skokie
skokie's Avatar
New dizzy bit got a miss.
Ok i got the new pertronix dizzy in along with all new plug wires. I fire it up and I got a miss. Thinking I was 1 tooth off I put the timing light on it and its set to 8 degrees. I have checked my wires again and I have em all on the right place. Anyone run into this one?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 07-22-2005, 01:08 AM   #2
jhow66
jhow66's Avatar
1-8-4-3-6-5-7-2---5 &7 not crossed? When does it miss--at idle-under load - all the time?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 07-22-2005, 01:13 AM   #3
skokie
skokie's Avatar
I am just running it at idle right now. Sitting at about 800-900 rpms.. 5 & 7 are not crossed from what I can see. I unplugged both and reran the plug wire.
68 build thread
Old 07-22-2005, 09:57 AM   #4
jhow66
jhow66's Avatar
Dual exhaust? Check to see which side.Then which cylinder on that side.
Old 07-22-2005, 10:17 AM   #5
cdowns
cdowns's Avatar
if it's a constant miss put your timing light on each plug wire till you find the one thats not firing// then try changing plugs between cylinders to see if it's a plug then switch wires to see if it's a bad wire
Old 07-22-2005, 11:19 AM   #6
skokie
skokie's Avatar
Cdowns I will try the timing light.
68 build thread
Old 07-22-2005, 11:26 AM   #7
panhandler62
Java Mechanic
panhandler62's Avatar
When you find the dead puppy.. check the wire and the connectors at each end. Sometimes the distributer end boots don't fit perfect and the contact isn't made.
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-22-2005, 01:14 PM   #8
Tim240Z
Tim240Z's Avatar
Also check the free play on the dizzy, at the rotor. Sometimes they need to be shimmed at the intake to space the dizzy body up a little. If it needs shimming it could be forcing the rotor into the cap and pushing it cockeyed? Been there, done that.....took me ages to figure it out too!
1972 Suburban C20
454/TH700R4, eaton-corporate 4.10 (looking for 3.7)
Sold: 71 Cheyenne 20
Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005)
Tim240Z is offline   Reply With Quote
Old 07-22-2005, 01:33 PM   #9
tomatocity
tomatocity's Avatar
check your distributor cap to see if the wires are connected in the proper sequence.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-22-2005, 02:08 PM   #10
matt67350
matt67350's Avatar
Check the plug gap. It changes when you go to HEI.
69 swb stepside, rebuild and upgrade in progress
matt67350 is offline   Reply With Quote
Old 07-22-2005, 03:30 PM   #11
skokie
skokie's Avatar
plug gap is .45. Will check the free play. Will recheck the wires tonight.
68 build thread
Old 07-22-2005, 11:25 PM   #12
skokie
skokie's Avatar
I found it. I had 2 and 4 crossed at the dizzy. Running great now. Thanks for all the help. Cant believe I crossed those
68 build thread
