Old 07-22-2005, 10:04 AM   #1
JonnyTechMech
STOP! Hamma time!!!
JonnyTechMech's Avatar
Question 87 Chevy/GMC dizzy upgrade or not
Hello all,
I got a question about the 87 dizzy in a Chevy/GMC model 305. It’s the factory model with the massive electronic connection on it that has variable timing control. It’s jacked into another electronic module setting on the engine. I don’t have the shop manual, so I can’t give you the exact terms. I don’t hear much about this type dizzy, so my question is:
With the factory electronic setup, can this dizzy be replaced with something more up to date? Or I’m I stuck with it unless everything goes. I get the feeling this will not be a cheap trick!
Also, has anyone used this type dizzy on a 327 or 427 block? The shaft & gear should work just the same, right?
JonnyTM
Plan your work and work your plan!!!, or pitty da fool!!
87 GMC BaseTrim, 305 under the wrench/TH400/
92 Chevy 1500, 350,TH700R4 sittin on dubs
JonnyTechMech is offline   Reply With Quote
