I have a '69 K20 with 350, Rockwell T221 xfer case, Eaton HO52 rear axle, closed-knuckle Dana 44 front (4.56's), and non-power drum brakes all around. I have a 4 wheel drive problem and am not sure if it is in the front diff, or the t-case.
Here's my Question: I have found a '76 K20 rolling chasis/cab that has a GM 12-bolt posi rear, open-knuckle disc brake Dana 44 front (4.10's), power brake booster and proportioning valve. Will these parts fit my '69??? I am not so much concerned with driveline length, but is the spring perch width the same on the '69 and '76??? Will the steering bolt up? Anyone that has a good knowledge of parts interchangability, I could really use some help here. Any info is much appreciated. Thanks In Advance . . . . Brian P.S. If the parts swap works out, is there anyone interested in this Eaton HO52 rear axle?
1969 Chevy K20 Fleetside 1979 Chevy K10 "ROBAHOR" (Rusted Out Beyond All Hope Of Repair) Last edited by wyoman64; 07-22-2005 at 02:40 PM. Reason: added info |
I make Models
![]() Join Date: May 2005
I dont know about the front differential....but I know on the rear that the perches for the springs are at a different width from 73-.....they dont interchange without moving the perches.....Paul
Born Psycho
![]() Join Date: Feb 2001
you will need to move the spring pads and one shock mount on the rear---if it's a 3/4 ton it should be a 14 bolt, not a 12 bolt. the e-brake cables will be too short also. the front is a direct bolt in but you'll need to adapt the brake lines for discs. the steering box off the newer truck is also a bolt in. it's really not a difficult swap. personally, i'd use a booster/master/prop valve from a 71-72 3/4 ton for ease of installation. all brake line adapters are readily available at your local parts house.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
