Old 07-22-2005, 06:13 PM   #1
BALDMIKE
Enormous Member
BALDMIKE's Avatar
What Chevy Man can answer this ?
Here's the deal:
When using the A/C, low and medium speeds worked fine, but when switched to "high speed" the blower motor just stoped blowing (didn't blow fuse)
* I thought it might be the high speed fan relay so I replaced that, now when I turn on the A/C, low and medium work as before but when I switch to "high" it pops the fuse "20amp". (didn't pop when using old H/S fan relay)
* I assumed the new high speed fan relay was bad and returned it for another new one only to find it doing the same thing.
* I unpluged the inline power condensor to the blower motor and it still poped the fuse when I turned A/C to "high".
* I unpluged the blower resistor and still poped the fuse when switched to "high".
I haven't tested the control panal in the dash yet, but was wondering if anyone had any other good ideas ?
"79" Chevy Stepside 350/350
Check my Blog @ www.BaldMikesWorld.blogspot.com
BALDMIKE is offline   Reply With Quote
Old 07-22-2005, 07:08 PM   #2
Bad Karma
Magnificent bastard
Bad Karma's Avatar
Check the fan switch in the dash, on mine the wires were melted and the switch was burnt.... But, I only had high speed and no others.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 07-22-2005, 07:21 PM   #3
BALDMIKE
Enormous Member
BALDMIKE's Avatar
I will check that Saturday, thanks Bro.
Anyone else ?
Old 07-22-2005, 07:55 PM   #4
full foot notch
look at the blower motor fan, possible resistance either mechanical or electrical that is drawing too much of a current when you switch it to high and that since its a current overload, is blowing the fuse, is you truck a glass fuse or plastic blade fuse type?
full foot notch is offline   Reply With Quote
Old 07-22-2005, 09:06 PM   #5
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Fuse is a plastic plug in yellow 20amp.
Think maybe the blower motor could be shorting this thing ?
Old 07-22-2005, 09:42 PM   #6
full foot notch
i would try unplugging the blower motor itself and put a DMM in place of the motor, so you can see if your getting voltage, and with the DMM in place, just see if your getting power there (most likely 12v at the high setting) and if it blows with the blower motor not connected its a short IMO, if it doesnt blow when the blower motor is disconnected, reconnect it and try, if it does then, its most likely the motor, at which point i would go buy another blower motor and plug the new one in and see if it does still pop
if ya do all that and it still blows, lemme know and ill look at teh schematic to see if it oculd be something else
Old 07-23-2005, 12:25 AM   #7
BALDMIKE
Enormous Member
BALDMIKE's Avatar
full foot notch
Thanks Bro I will check it out and ost back.......
Old 07-23-2005, 03:57 AM   #8
cliffsta
Stepsides RULE
cliffsta's Avatar
Yeah sounds like the switch... mine doesn't work on high but on the rare occasions i throw the switch back and forth really quick, sometimes it'll jump into high....
My dash bezel is just so brittle, so i don't take it off unless i gotta
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 07-23-2005, 01:54 PM   #9
BALDMIKE
Enormous Member
BALDMIKE's Avatar
cliffsta I will check the switch also.
BTW cliffsta why do you hate your life ?
Old 07-23-2005, 04:06 PM   #10
cliffsta
Stepsides RULE
cliffsta's Avatar
LMAO I dunno. It was a joke.
Basically, kinda like, whenever life sucks, i just jump in my truck and go for a joy ride.
You could complete my avitar by making it:
I hate my life.... when i'm not in my truck
Old 07-23-2005, 04:41 PM   #11
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Fair enough, lol.................
Old 07-24-2005, 02:26 PM   #12
full foot notch
so you figure it out yet baldmike
Old 07-24-2005, 03:39 PM   #13
BALDMIKE
Enormous Member
BALDMIKE's Avatar
No not yet, I had to do a family thaing Saturday.
I hope to check out the fan switch and some other things Sunday or Monday.
All I know is it's too damn hot with no air, lol..........
Old 07-25-2005, 10:08 AM   #14
86 GMG
you might check the wireing harness to the blower ,a/c, heater unit see if there is a wire that is opened and shorting it out
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
Old 07-26-2005, 11:35 AM   #15
flip66
flip66's Avatar
Check the blower motor common problem when the motor is bad. I know the problem in GM G Body cars 90% of the time it was the blower motor.
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 07-26-2005, 01:40 PM   #16
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Well I'm down to checking the blower motor itself,must be it ?
Will post back, and thanks to all.......
Old 07-26-2005, 06:51 PM   #17
phantom dually
Project92 SWB stepside
phantom dually's Avatar
There is a relay outside under the hood where the blower bolts up. Change the relay and you should be set.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 07-27-2005, 06:14 PM   #18
BALDMIKE
Enormous Member
BALDMIKE's Avatar
Are you talking about the high sped fan relay or the tube shaped relay ?
I already replaced the H/S fan relay.......
