Oilfield Trash
How To Replace Vent window handles
I was wondering how can I remove and replace the vent window handle in my 72?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Using a 3/32" punch drive out the small pin in the handle and the handle will come off easily. Putting it back together is pretty easy also but you have to compress the wave washer to get the pin to drive in straight. I would suggest adab of grease on the shaft after cleaning it.
If you want to remove the part out of the window, the inside ferrule is threaded onto the outside part. The ferrule has two flats on it to fit a 9/16" open end wrench. Since the glass retains the outside part take care not to put two much force on the ferrule or you could possibly break the glass. Jim |
A 6 penny nail works for pushing out the pin also if you don't have a punch.
