Old 07-22-2005, 10:21 PM   #1
69 Short Fleet
Question Accel HEI Coil Question
Anyone running a Accel HEI super coil (Pt. #140003)? Has a red & white wire, is this the correct coil for my HEI upgrade (Accel makes one other simular to this one, can't remember the part #). Is it a decent coil and much better than a stock GM one? I'll be buying a new coil for my HEI would like to know what is a good choice. I am running Taylor Thundervolt 50 wires (10.4mm) Thanks, Doug
69 Short Fleet is offline   Reply With Quote
Old 07-22-2005, 10:31 PM   #2
rage'nrat638
rage'nrat638's Avatar
the difference between stock is 30,000 volts and the high pro aftermarket
ones are 50,000 volts.....
make sure you still use your stock black ground wire......once you take the top cover off you will see it........
i run the 50,000 volt coil.....and have no problems........the brand your looking at is good......mark
rage'nrat638 is offline   Reply With Quote
Old 07-23-2005, 04:08 PM   #3
69 Short Fleet
Mark, is your Accel coil the same one that I'm looking at buying? Pt. # 140003 with the 2 wires (one red, one white). Accel makes two almost identical looking ones but the other coil they sell has like 4 wires (I think it is for the new style HEI). I just want to make sure I buy the correct one as I am buying it on line. Thanks, Doug
Old 07-24-2005, 12:14 AM   #4
rage'nrat638
your truck only needs the two wire plus the added black wire from your stock coil.......your on the right track.....
Old 07-24-2005, 12:21 AM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
get a msd 6 al box too if you want more power arrrrrrrrrr arrrrrrrrrr
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-24-2005, 02:46 AM   #6
69 Short Fleet
OK, thanks Mark. Doug
