07-23-2005, 08:23 AM | #1 |
woodman13
DEAD HORSE: what is it worth 68 SWB?
I know, I know ... done a thousand times. Just doing a sanity check before I buy it. I am looking at a 1968 Chevy SWB fleetside, 350, T350 trans, lowered 4-6", disk brakes on front, shaved door handles, no rust to be seen, minor dents/dings here and there, not a/c, p/s, p/b, 10 bolt posi 3:73, %"tach with matching gauges, B&M floor shifter. The motor is a 355, dart heads(not aluminum), headers, g team intake, MSD electrics, Holley 750DP, suppose to be forged crank and pistons(11.5-1). Motor does not run, the guy said it jump time or chain is stretched. Missing gauge housing, interior is old but there, primed, gas tank in the bed(fuel cell 15 gal), windshield broken/cracked) older rims with some rust on them fair tires.
I know without pics it is hard to tell, but trying to get a ball park estimate. Asking price is $2000, but he needs to sell bad.
Woodman13 2007 Dodge Ram 3500 5.9 rolling coal! 1994 Caprice 9C1 88K miles, LT-1, dropped/shaved 1967 C-30 350 4 sp dually 1971 C10 SWB BBC, auto; good driver |
07-23-2005, 09:24 AM | #2 |
Sounds like a good price to me, but pictures would sure help.
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-23-2005, 09:26 AM | #3 |
Even without the motor that's not bad.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
07-23-2005, 09:28 AM | #4 |
Sounds Good to me.
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
07-23-2005, 09:30 AM | #5 |
Working on a Nova.
If the Dart heads are in good shape they are worth a buck or two. Actually I'm looking for a set. The Posi is a good thing too. That truck has a lot of valueable parts on it. As for fixing it up, it all depends on how you want to fix it up. Alot of work would be required to get it back to an origional truck. If your looking for a slammed and trimmed truck this could be the way to go since some of the work is already done. Just make sure it is quality work since it is harder to go back and redo then it is to do it yourself from an origional. With the drop on the truck I would also want to jack the truck up and carefully inspect the frame for any alterations, damage, or severe rust (not normally a problem in texas unless your by the coast). Also make sure the title is free and clear. If you live close to Mexico I've heard you can have problems with this.
07-23-2005, 11:17 AM | #6 |
Thats a lot of motor to only have a 15 gal fuel tank. The 10 bolt rear is not original. wonder how he switched to disk front? Hope it was done right. All in all it sounds good, but you may find that stuff wasnt done right. and that motor just "jumping timing" doesnt sound right. and a streched chain wouldn't make it not run. Still it is probablly worth it.
For every person with a spark of genius, There are a hundred with ignition trouble. 70 Short/Step |
07-23-2005, 11:59 AM | #7 |
The cylinder heads alone are almost worth half that.
07-23-2005, 12:25 PM | #8 |
woodman13
Yeah, I was thinking the same thing on the price, just wanted a sanity check from you guys. I actually think I can get it for the $1200-1500 range. I was thinking of a slammed, shaved, 4L60/700R4 trans, canary yellow with silver ghost flames, black interior and tame the motor down a bite(9.5 pistons), 17X8 rims and drive it like I stole it.
314 days till the 2006 Power Tour!!!!
07-23-2005, 12:26 PM | #9 |
woodman13
I'll post some pics when I finish the deal!!!!!
