07-23-2005, 09:09 AM | #1 |
What have i got myself into????
Just kidding... Look what i started yesterday evening.... Painless 18 circut wiring harness. Complete replacement for every single wire in my truck... It has been really simple so far.. wires labled and prebundled.
Although i will say it is pretty intimadating opening up that box and seeing all those wires.... WHEW!!! here are some pics so far..
https://www.ebay.com/itm/29620574751...mis&media=COPY |
07-23-2005, 09:10 AM | #2 |
heres one more
07-23-2005, 09:21 AM | #3 |
Did you have to cut the firewall? What part number did you use? Who did you purchase from? How much? Good luck!
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
07-23-2005, 09:27 AM | #4 |
Looks like aliens jumped outta yer dash! Bet it'll be nice when you're finished. That task would intimidate me a bit (having never done it).
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
07-23-2005, 10:11 AM | #5 | |
07-23-2005, 11:58 AM | #6 |
Got Light Emitting Diode?
you needed a hammer to run wires in your truck
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
07-23-2005, 02:48 PM | #7 |
It's not too bad if you take your time and check things out as you go along.
Couple of observations... There's a few funky things about the way they are wired up that you might want to think about while you're there... some of it you might not care about. One thing you might not notice until you are done (I didn't) is that the power to the radio does not come off of the accessory circuit, so when you turn the ignition to the left, no radio. Easy enough to fix while you're at it. Other things that I thought were pretty weak (but you might not care about) include their "work around" if you are using a high output alternator w/ a lot of accessories, and the power window wiring is always hot... not keyed. You may also want to rewire your side markers to work with the parking lights. There's probably a few other things that I forgot...
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
07-26-2005, 09:15 AM | #8 |
Well got her all buttoned up last night and i can say that it was the easiest wiring job i have ever done... It is just really really really time consuming. Although i do have one question.. last night when i started her up she was running great and when i shut her off SHE WAS STILL RUNNING GREAT!!!! it wouldn't shut off.. I traced the prob to the wires comming off the alternator.. I think i am getting some feedback from the alt. exciter wire and it is keeping the system powered up.. (it will work and shut off just fine with the plug on the alt. disconnected) So can i just go and get a one way diode and splice it into that wire? I think that might work...
I would recommend the painless wiring kit to anyone.
07-26-2005, 09:32 AM | #9 |
70'_402: Did you get to specify things, like V-8, HEI, automatic/manual etc... or is it "one size fits all" with extra wires? I also have the 67 "3 dislplay" dash and would like to switch to one that has all the gages. Is there any specification on this, or does it come wired for either one??? Thanks
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
07-26-2005, 12:22 PM | #10 |
It comes wired for evey option that was offered and some that weren't.. you can either wire up the guage pod with lights or with guages.. as far as hei, you just bypass the ballast resistor and wire directly to the distributor....very simple
as far as specifics, you will have some extra wires for options that you don't have or need. one size fits all i guess you could say.
07-26-2005, 02:47 PM | #11 |
I just used the Painless harness for my 383 TPI wiring and it worked awsome, and easy to do.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
07-26-2005, 03:28 PM | #12 |
pics
any pics of completed installation and words of wisdom for others considering this upgrade?
Bob |
07-26-2005, 08:47 PM | #13 |
yes,i agree,when i started mine,i was really overwhelmed,but as you go,pice by piece,it gets easier and easier,worked out great for my power locks and windows
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
07-26-2005, 09:10 PM | #14 |
fantastic im in. and thanx for sharing
07-27-2005, 10:03 AM | #15 | |
07-27-2005, 03:51 PM | #16 |
Re: Painless
Kudos to Painless. I went through this setup not long ago...well I'm sort of still doing it as I add more gizmos like a radio, A/C, etc...
It sure is nice to have modern fuses and labeled wires. Although I'm still trying to figure out where my cruise control wire from painless plugs in.. 'til I do, I'll just keep using my floormat propped against my gas pedal.
Only the Mediocre are always at their best... '69 GMC LWB 406, TH400, 3.73 Posi' Things I've learned from my truck...If I was an automaker, my vehicles would be overpriced, run rough, and get 5MPG. |
07-27-2005, 04:10 PM | #17 |
Nothings as cool as my 72
I think I'm going to let my dad do the wiring in my truck. That looks way to complicated for me to do, especially scince I have never none anything like this in my life.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
07-27-2005, 11:40 PM | #18 | |
07-29-2005, 07:45 AM | #19 |
Looks like a electricians nightmare!!!!! all too soon I will be going through this myself but going to use a EZ wire---anyone use this brand?
07-29-2005, 06:15 PM | #20 |
Seasonal Poster
Would you even go as far as saying it was painless?
67 GMC Short Step 350/4-Speed/3.08 Posi Front/Rear Sway Bars Kelowna BC, Canada Member of DTPW |
