Old 07-23-2005, 11:06 AM   #1
KEH
Better late than never
KEH's Avatar
Coolant recovery tank
I have been using an empty Prestone jug stuffed in the opening by the battery as my overflow for too long now. I would really like a mounted see-thru bottle instead. Who has a solution? Thanks.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 07-23-2005, 11:13 AM   #2
cantontruck
cantontruck
You can purchase a univeral tank at O'Reilly's for around $10.00. I just bought one. Looks like it will have to be installed on the driver's side of the radiator.
cantontruck is offline   Reply With Quote
Old 07-23-2005, 11:51 AM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
peel the lable off of a pepsi bottle. see-thru. and your only out 5 cents
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 07-23-2005, 12:05 PM   #4
Mudder
Post Whore
Mudder's Avatar
Wes sells them.
Mudder is offline   Reply With Quote
Old 07-23-2005, 03:13 PM   #5
pickemup
Talking
i fabbed my own out of a car . i welded some sheet metal onto the battery tray
about 8 inch's X 10 i think it was. the size of the jug anyway and it looks pretty good and best of coarse is that the hose reaches better. i have to get a pic of that it looks like a stock piece.
now i remember it was an windshield washer bottle
pickemup is offline   Reply With Quote
Old 07-23-2005, 08:48 PM   #6
tomatocity
tomatocity's Avatar
here are some options I have been considering.
Simple if you can get the caps. gmparts direct has them but you have to buy 5 at a time.
http://67-72chevytrucks.com/vboard/...d.php3?t=163396
Here are three different I have in my garage. Chickenwing knows what the larger one is. more to come...
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-23-2005, 08:50 PM   #7
tomatocity
tomatocity's Avatar
excuse the crummy looking engine area. The larger one does not sit perfect to inner fender well and should be spaced (but not much) on the two lower anchor points. Hope this helps.
Old 07-23-2005, 11:04 PM   #8
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Keep it simple...
IMO nothing looks better or fits better than the matching WS bottle on LH side and same bottle, in same location, on the RH side. You need that GM cap that is getting hard to find. Check your local GM dealer for #340194. GM parts direct does not have any left.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 07-23-2005, 11:49 PM   #9
71-longbed
Its Magically Delicious
71-longbed's Avatar
my washer doesnt work .. so i ran a hose from my overflow nipple .. underneath the radiator to the washer fluid container.. works great ... just a thought
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 07-24-2005, 12:11 AM   #10
tomatocity
tomatocity's Avatar
that is what PICKMUP is using with the bracket and the 2-way cap. They look very nice located near the primary battery.
Old 07-24-2005, 12:31 PM   #11
neonlarry
neonlarry's Avatar
These are what I used, out of an 80's G-Body.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 07-24-2005, 01:37 PM   #12
KEH
KEH's Avatar
Thanks for the replies. I ended up buying one from WES:
Old 07-24-2005, 04:41 PM   #13
greenhorn male
greenhorn male's Avatar
Hmmm...my winshield washer container is on the passenger side like that overflow bottle. Does this have something to do with my auxilliary battery and custom camper wiring or did the previous owner move it.
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 07-24-2005, 05:17 PM   #14
tomatocity
tomatocity's Avatar
most likely the PO moved it.
Old 07-24-2005, 05:22 PM   #15
tomatocity
tomatocity's Avatar
neonlarry, pm me about your t-stat housing, nipples and plugs I see on your intake manifold. I am in the process of repairing my intake manifold or replacing it and I would like to use quality parts at a reasonable price. Is that a Edelbrock 2101? I am looking at a 2701 with a 1406. Thanks.
Old 07-24-2005, 07:11 PM   #16
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Check on ebay, there are some nice ones on there, if you are not looking for an original. Search "radiator overflow tank" or something like that. That's where I got mine. http://cgi.ebay.com/ebaymotors/ws/eB...tem=7987729831
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 07-24-2005, 11:33 PM   #17
Rod
Could go with a factory overflow coolant tanks also. They were available back when.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 07-25-2005, 12:59 AM   #18
tomatocity
tomatocity's Avatar
I had one of those on my 62 Impala SS and the only thing missing was being able to see the water level at a glance.
Old 07-25-2005, 08:37 AM   #19
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I have a 72 camper special. Mine was mounterd on the passenfer fender also. My battery isolator relay was mounted on the drivers fender...
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 07-25-2005, 08:38 AM   #20
chickenwing
What did it look like? Pic?
Old 07-25-2005, 10:44 AM   #21
greenhorn male
So, this could be factory or dealer installed, then. That insulator or whatever the camper wiring connects to, seems to be in the way of installing the washer bottle on the drivers side. I wonder if others were mounted on the passenger side.
03 Tahoe
Old 07-25-2005, 03:10 PM   #22
tomatocity
tomatocity's Avatar
Can you send a photo of your factory passenger mounted windshield cleaner bottle? Thanks.
Old 07-25-2005, 03:26 PM   #23
greenhorn male
Here you go. The bracket is attached to the fender with 2 vertical screws only.
03 Tahoe
Old 07-25-2005, 06:48 PM   #24
tomatocity
tomatocity's Avatar
Thank you. I would like to get my hands on the bracket so I could copy it. This is hte first time I have seen one of these. Rich (chickenwing), do you have this bracket? Don't tell me you gave it away
Old 07-25-2005, 08:39 PM   #25
greenhorn male
The whole bracket holding the bottle, including what is touching the fender is one piece.
03 Tahoe
