07-24-2005, 08:46 AM | #1 |
AUSTIN TX
Truck Is running like crap
well i finish intalling the head gasket on my 305, after finishing i ran the truck and it ran good for the 1st 3 miles and then it started running very ruff, I thought it was the timing but the timing is good, I double check distributor and its also good, i placed piston #1 top dead center and checked the distributor and its pointing to piston #1, do i need to rotate the distrubutor again, and line it up again. Im lost right now dont know my next move, please help.
07-24-2005, 10:12 AM | #2 |
I think I would double check the valves (too tight or too looses) and check the head bolts (may need to re-tourque). As for the dizzy, do you have a computer on the vehicle? If you do, I think the timming is controlled by that, cannot adjust without a special plug for the computer. If not, the rotor should be pointing to the #1 lug on the dizzy, not the actual #1 piston in the block. Hope this helped.
07-25-2005, 09:25 AM | #3 |
AUSTIN TX
Thanks for the response Nolowrider, I tourque all the bolts to spec from the heads to the intake manifold, Heads Torque to: 65 ft-lbs, manifold to: 30 ft-lbs. There is no computer on the truck. right before putting all back i made sure that the timing was set correctly and it is pointing to the #1 lug instead of the #1 piston. The Valves looked good when i reinstalled the heads. I was told that it could be my fuel injected carb, but i never missed with it, when i replaced the heads, Is there anything that can go wrong with the carb if i took it off?
07-25-2005, 10:27 AM | #4 |
i dont know for sure so take this with a grain of salt but it seem to me a trottle body carb can get messed up some how if you take it off and turn it upside down? like i said i dont know for sure come on guys out there help educate us young wiper snappers
square body trucks an addiction or an investment either way they consume all my extra time and money |
07-25-2005, 11:32 AM | #5 |
AUSTIN TX
I did turned it upside down when i cleaned the carb, is there something that i must do to check the carb out and make sure all the interior components are working properly.
07-25-2005, 01:14 PM | #6 |
Parts and more parts
You say the valves looked good. Did you take the head off and re-install it without adjusting the valves? That is a no-no, you should adjust the valves when you do work like this.
07-30-2005, 11:50 PM | #7 |
Could be bent push rod 1 or more , did you check distributor cap for chip or crack , heaven forbid flat lobe on camshaft.
07-31-2005, 11:20 AM | #8 |
7000 #'s of american IRON
something tells me that is probably the problem..
