Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-24-2005, 08:17 PM   #1
masterbeavis
Having issues
masterbeavis's Avatar
K30 14B, 4.56 gears, open
came from a one ton. It is the late model 14B, but the hubs mount behind the hub. Has the big brakes. It does not leak, brakes work, ring and pinion in good shape. 1350 yoke. 4.56 gears, open diff, 9/16" wheel studs, single wheel application. Looks like the WMS is 67", it matches the front 60 I have on my blazer pretty close. Spring pad spacing matches that of my first gen blazer(half tonwidth) @ 40". Axle is located in Eldorado CA, and local delivery to sac area avail. for gas kmoney. $200 as is, where is. shipping cost is one million dollars. payable in cash
Needs hard brake lines, and ebrake cables. Needs shock mounts welded on as well. Housing has been cleaned up, if you like I can paint it.
masterbeavis is offline   Reply With Quote
