Old 07-25-2005, 08:12 AM   #1
fade94
fade94's Avatar
Speedo gear color?
How can I determine what speedo gear color I need? Truck had 3 speed now has TH350.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 07-25-2005, 08:22 AM   #2
jcarlar1
You Are Not Forgotten
jcarlar1's Avatar
speedo gear
Go to bowtieoverdrives.com and you can find all info you need.
If you don't know where you are going, any road will take you there!
jcarlar1 is offline   Reply With Quote
Old 07-25-2005, 08:24 AM   #3
fade94
fade94's Avatar
That was fast. Thanks.
Old 07-25-2005, 08:25 AM   #4
fade94
fade94's Avatar
Then don't show anything for a TH350, only OD trans.
Old 07-25-2005, 08:39 AM   #5
jcarlar1
jcarlar1's Avatar
speedo
sorry fade, bot i thought that the drive and driven gears were interchangeable, good luck in your hunt.
Old 07-25-2005, 09:05 AM   #6
cowboy33713
Howdy-
If you have a transmission parts supply house near you, they may be able to help. At a local ( to me in St Petersburg, FL) AC DELCO supplier/ warehouse, I have seen a application guide in which , by transmission type, there was listed, year by year, the make/model, rear end ratio, and then the correct speedo gear by color, number of teeth, and part #. They guarded that info closely until they couldn't find a listing,( they had little old truck info) then they handed me the book to pick something that would work in my truck, as the trans is a common T400.
Good Luck! Hope this helps.
cowboy33713
cowboy33713 is offline   Reply With Quote
Old 07-25-2005, 09:06 AM   #7
pjmoreland
pjmoreland's Avatar
They aren't interchangeable.
pjmoreland is online now   Reply With Quote
Old 07-25-2005, 12:00 PM   #8
demi
demi's Avatar
Try here.
speedo gear
demi is offline   Reply With Quote
Old 07-25-2005, 01:20 PM   #9
fade94
fade94's Avatar
So far, none of the sites I have tried actully give a calculator. I need to determine what gear I need for a 3.07 rear and 235*75 R15 Tires.
Old 07-25-2005, 01:25 PM   #10
/<eystroke
/<eystroke's Avatar
235x75 R15 with a 3.07 rear
Turbo 350
Code:
Finding best gear combo...
Drive Gear	Driven Gear	Correct
20 (brown)	43 (purple)	0.27%
19 (yellow)	41 (yellow)	0.64%
18 (blue)	39 (brown)	1.04%
17 (red)	36 (white)	-1.24%
17 (red)	37 (red)	1.48%
18 (blue)	38 (blue)	-1.56%
9 (green)	19 (natural)	-1.56%
19 (yellow)	40 (black)	-1.84%
20 (brown)	42 (green)	-2.09%
10 (red or purple)	21 (red)	-2.09%
10 (red or purple)	22 (gray)	2.54%
20 (brown)	44 (dark gray)	2.54%
19 (yellow)	42 (green)	3%
9 (green)	20 (blue)	3.51%
18 (blue)	40 (black)	3.51%
17 (red)	38 (blue)	4.08%
17 (red)	35 (orange/pink)	-4.13%
18 (blue)	37 (red)	-4.3%
19 (yellow)	39 (brown)	-4.45%
20 (brown)	41 (yellow)	-4.58%
8 (orange)	18 (brown)	4.7%
20 (brown)	45 (light blue)	4.7%
19 (yellow)	43 (purple)	5.26%
18 (blue)	41 (yellow)	5.87%
17 (red)	39 (brown)	6.54%
19 (yellow)	38 (blue)	-7.2%
17 (red)	34 (light green)	-7.2%
9 (green)	18 (brown)	-7.2%
18 (blue)	36 (white)	-7.2%
10 (red or purple)	20 (blue)	-7.2%
20 (brown)	40 (black)	-7.2%
19 (yellow)	44 (dark gray)	7.41%
18 (blue)	42 (green)	8.11%
9 (green)	21 (red)	8.11%
17 (red)	40 (black)	8.87%
19 (yellow)	45 (light blue)	9.47%
8 (orange)	19 (natural)	9.72%
20 (brown)	39 (brown)	-9.95%
'69 C/10 Short Wide
350/400/AC/Tilt/Tach
/<eystroke is offline   Reply With Quote
Old 07-25-2005, 02:06 PM   #11
Blue_71
Bloo
Blue_71's Avatar
keystroke- may i ask where you got that info? i need to find out what i need for my th350, i have 275/60/15 rear tires and if i remember right the gear that the cable hooks to is green. i was told the rear gear was 4.10, but i need to check it
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 07-26-2005, 03:37 AM   #12
jimfulco
http://novaresource.org/speedo.htm uses tire diameter & rear end ratio to tell you what speedo gear ratio you need.
http://tciauto.com/tech_info/speedo_gears.htm converts tire size to tire diameter, and also has a list of gears for different transmissions. Click on part numbers & it will cross-reference with GM part numbers.
http://www.bgsoflex.com/speedo1.html may also be helpful.
jimfulco is offline   Reply With Quote
