Old 07-25-2005, 07:06 PM   #1
guyryan100
guyryan100's Avatar
Too close to header?
Are my brake lines too close to the header? If you can't tell in the pic it's about 3/4" between them.
guyryan100 is offline   Reply With Quote
Old 07-25-2005, 07:07 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
YIKES, That is pretty close, but I'm no expert on whether or not it's a issue
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-25-2005, 07:19 PM   #3
tomatocity
tomatocity's Avatar
It would make me uncomfortable but like LUV I am not an expert. What does everyone else do? Anyone have pics of theirs installations?
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 07-25-2005, 07:28 PM   #4
guyryan100
guyryan100's Avatar
I guess it could only be an issue if the truck were ever actually cranked and driven out of the garage, so I may be safe at the rate I'm going.
Old 07-25-2005, 07:29 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yeppers, but mine is a 4wd so it doesn't count
Old 07-25-2005, 07:44 PM   #6
matthufham
when you open throttle the engine might shake and hit them.
matthufham is offline   Reply With Quote
Old 07-25-2005, 07:46 PM   #7
frost89434
frost89434's Avatar
I drove my old truck for years with them just like that and did not have an issue. I even drove it 900 miles.
68 short fleet with 71 front clip 2wd jaguar blue
99 chevy ext cab shrtbed z71 loaded
99 chevy swb fleetside(daily driver)
Sparks, Nevada
frost89434 is offline   Reply With Quote
Old 07-25-2005, 08:34 PM   #8
arkracing
Weekend Warrior
Probably not....it COULD happen but probably not. when you floor it the left side of the motor raises up and away from the frame with the torque transfer (watch a drag car...usually the left front wheel will lift first)
as far as if they are too close...I would be afraid of boiling the brake fuild. I don't think it would get hot enough to do that but i would want to take the chance. the cheap and easy way out would be to buy some heat reflective tape (Summit & Jegs or your local speed shop) and wrap the lines in that area.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 07-25-2005, 08:42 PM   #9
FirstGen
Just Don't Stop!
FirstGen's Avatar
Mine are every bit that close. 7200 miles and no problems yet... no insulation either...
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 07-25-2005, 09:01 PM   #10
tomatocity
tomatocity's Avatar
And that can be very hot country. So this answers my concerns. If he does not get brake fade then there should be little concern. 'Keep'em On The Road'
Old 07-26-2005, 03:54 PM   #11
72MARIO
72MARIO's Avatar
I ran mine on the outside of the frame for peace of mind.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-26-2005, 04:02 PM   #12
Fred T
Cantankerous Geezer
Fred T's Avatar
I would at least make a heat shield out of aluminum. If it were mine I would run the lines outside the frame. It's not that tough to bend your own.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-26-2005, 04:03 PM   #13
cableguy0
mine are about that close and have been since the truck has had headers way back when my dad had it. rough estimate is 50k miles or so and never an issue. especially with the ceramic coated headers they hold the heat inside the pipe and dont let near as much into the engine compartment
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-26-2005, 04:12 PM   #14
boraxman
Keepin an eye out
boraxman's Avatar
Mine are at least that close...no issues.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 07-27-2005, 11:53 PM   #15
purple gas
Mine are that close too. I only have a few miles on it and was slightly concerned. But as stated above. Brake fluid is built for very hot conditions. Still, I may eventually move mine. I'm thinkin it must get REAL hot there.
I got a bench seat baby, you don't have to sit over there.
purple gas is offline   Reply With Quote
Old 07-28-2005, 12:36 AM   #16
Low69CST
it looks like your headers are ceramic coated. I've been told that is enough of a insulator that it keeps the heat inside the tubes and not much radiates in the engine compartment. However, I have heard of brake fluid boiling. I changed my lines like Mario to outside the frame and bought some insulation and wrapped the lines. I think the closest I get is about 1.5"-2". You may want to look on the other side under the truck. Where the rear line goes from the crossmember to the pass. frame rail was actually touching my headers. I had to change them around to the outside the frame rail.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-28-2005, 09:34 AM   #17
Gray Ghost
Gray Ghost's Avatar
If they aren't within 1/2" they should be okay, but I'd get a second set of eyes on it when you torque the motor just in case. When I installed the headers on my Elky, the brake line was close enough that torkin' the motor put a hole the brake line. Took me several days to figure out there was a problem...coulda been real dangerous....
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 07-28-2005, 10:05 AM   #18
GloryHound
Working on a Nova.
GloryHound's Avatar
Most of the new brake line kits put the lines on the outside of the frame rail. You should be able to get a new set of front lines for less than $100.00. Even though your clearance may not be an issue, I like the peace of mind running it on the outside would give me. New brake lines are always a bonus anyway! You may even want to think about going to stainless brake lines while your at it. A complete kit will run you around $200.00 to $250.00. With this you'll gain a lot more peace of mind. I'd hate to see someone put all the time, money, and effort into fixing up a nice looking truck just to rearend someone or hit a tree and total it shortly after getting it on the road. Alot of attention has been turned to brake systems in alot of auto magazines. Is this for a reason? I think so.
GloryHound is offline   Reply With Quote
Old 08-01-2005, 09:40 PM   #19
67chops
67chops's Avatar
I know I need to get this fixed, but my front brake line is touching the header. I have driven on it every day for the past 2 months without a single problem.
-Chops-
67chops is offline   Reply With Quote
