Old 07-25-2005, 07:49 PM   #1
magooster
'65 GMC Project
magooster's Avatar
Shorty Headers
Has anyone found a set of shorty headers for 60-66 Chev/GMC? I have read another thread on this site where someguys were using Chevelle headers for their 67-72's. I always thought that the frames were mostly the same and the headers would fit both eras of trucks, but all of the header vendors have separate listings for them. Thanks in advance.
magooster is offline   Reply With Quote
Old 07-26-2005, 12:23 PM   #2
ozzyracing
What engine are you using, I have headers on my 65 GMC 1/2 ton with a 454.
65 SWB 454 350T
ozzyracing is offline   Reply With Quote
Old 07-26-2005, 03:18 PM   #3
ed455
Captain Ed
The frame rails have a wider horizontal cross-section which makes for a little less clearance. For that reason there is sometimes slight clearance issues. Big blocks especially have this problem. I notched my frame with a cut-off wheel 1/2" deep by about 4" long. It turns out that I would have been close but not quite touching. I'm still glad I did it, because it makes even full length header installation a breeze. I have 1-3/4" primaries on my 406 and it still cleared.
Ed
ed455 is offline   Reply With Quote
Old 07-26-2005, 03:19 PM   #4
ed455
Captain Ed
Oh, and they're Hedmans.
Old 07-26-2005, 05:23 PM   #5
magooster
'65 GMC Project
magooster's Avatar
Sorry, I forgot to mention I'm running a 400 small block
Old 07-28-2005, 05:06 AM   #6
cajunbowtie
ed455, I'm about to put a BB in my 65' You said you use Hedmans do you have the stock or part #.
Thanks,
cajunbowtie is offline   Reply With Quote
Old 07-28-2005, 09:12 AM   #7
ed455
Captain Ed
My 406 is a SB. Sorry.
Old 07-28-2005, 09:21 PM   #8
Slammed66
Needs a Big Block
Slammed66's Avatar
Im running hooker 3/4 legth hedders on my 64 Ill get you the part number tonight they fit perfect , I was able to run all my exaust above the frame rail .
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 07-28-2005, 11:17 PM   #9
magooster
'65 GMC Project
magooster's Avatar
Thanks that would be great. I have always preferred Hooker over Hedman.
Old 07-30-2005, 02:59 AM   #10
speedking
Do the "block-hugger headers work on the '60-'63 models w/smallblock? I kinda figured they would,since my truck came with the center-dump rams horn manifolds,but that's a pretty big investment to make,only to find out they can't fit.
Speed
-57 GMC 1/2 ton longbed,Pont. 400,4 speed
-62 Chevy 1 ton duallie,Chevy 355,4 speed
-66 Pontiac Catalina 2 dr. hardtop,389,T-400
-81 Ford Fairmont wgn.,2.3,4 speed
-68 Triumph TR6-R 'cycle,various mods
-66 C-60's back
-there's probably others...
speedking is offline   Reply With Quote
Old 07-30-2005, 05:57 PM   #11
fchava
fchava's Avatar
slammed,
did you find a part number for the headers?? Would love to put 3/4's on to get rid of the block huggers.
fchava is offline   Reply With Quote
Old 08-05-2005, 02:23 AM   #12
magooster
'65 GMC Project
magooster's Avatar
Slammed, I would still really appreciate that Hooker part #. Are they the ones that fit Chevelles??
Old 08-08-2005, 02:38 AM   #13
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
I know the full length headers my brother-in-law is running on his '65 swb stepside (350sbc-th400 trans) is running late 60-early 70's chevelle headers.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 08-14-2005, 01:57 AM   #14
fchava
fchava's Avatar
found these shorties
headers
Old 08-14-2005, 01:42 PM   #15
magooster
'65 GMC Project
magooster's Avatar
Those look cool, but I was hoping to find a part number that I could take to my local speed shop like Hedman, Hooker etc. Ordering stuff across the border is a pain in the A$$. Duty, Taxes, Brokerage Fees etc.
Old 08-14-2005, 07:13 PM   #16
rsp73538
Shorty Headers
I just put dual exhausts on my 66 with 327 V8. I had the problem with the headers and exhaust pipe not clearing the cross member. I had a local muffler shop make me a pipe with 2 each 45 degree bends in it, ($10). I cut this pipe into 2 pieces, each about 5 inches long. I then used one piece for each side, hooking them up to the exhuast flange, with couplers from Autozone. The headers I was using were 2" outlet pipes and the exhaust system I got from JC Whitney were 2 1/4" pipes. So the coupler I bought were 2" on one side and 2 1/2" on the other end. With the 45 degree bend in place the exhaust pipes cleared the crossmember with no problems. I used pipe clamps to hold it all into place until I got it all permanently welded. Using this method I didn't have to notch the crossmember.
rsp73538 is offline   Reply With Quote
Old 08-15-2005, 08:23 PM   #17
magooster
'65 GMC Project
magooster's Avatar
Thanks, but because I don't want to run full length headers,(they'll drag on the ground) I'm more concerned with 3/4 length headers interfering with the engine towers.
Old 08-15-2005, 08:25 PM   #18
magooster
'65 GMC Project
magooster's Avatar
Slammed66, I'm still hoping you'll come through with the Hooker part number.
Old 08-16-2005, 01:14 AM   #19
fchava
fchava's Avatar
i called Rewarder today and the guy there has two 66 chevy trucks himself, any how he said that the chevelle headers fit the same. On another forum a guy told me that he used the patriot 3/4 chevelle headers , but had to change motor mounts to the tubular type like the truck shop sells.
