Old 07-25-2005, 10:45 PM   #1
Jefe
Jefe's Avatar
Quick 383 Balance Question..
I'm just about ready to build my 383 and I am going to mate it to my Muncie 4 speed in my '68 shortbed. I was wondering if anyone has used a 383 Balance Plate that bolts between the crankshaft and the flywheel? I am kind of weary on using such a thing, but dont really want to buy a manual flywheel for a 400sbc. Any opinions? Thanks!
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed
-1968 Chevy SWB = numbers matching 307/Truck 4 speed.
-1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC
-1972 Chevy Nova = 2 door/412 Small Block
-1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything.
Jefe is offline   Reply With Quote
Old 07-25-2005, 11:22 PM   #2
rage'nrat638
rage'nrat638's Avatar
if the crank was balanced .....it should have had the fly wheel bolted to it to do it correctly !!!!!!
rage'nrat638 is offline   Reply With Quote
Old 07-26-2005, 12:02 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
external balance should have the flywheel and clutch assy on for balancing
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-26-2005, 10:35 AM   #4
69 longhorn
^ what they said! External balance is a little funny to deal with, you can swap flywheels a get a vibe on a stocker. I have seen guys use that balance plate, but i dont think its the best thing to do. If you havent assembled the engine.....best bet would be to take the balancer,crank, clutch cover & flywheel in to have it balanced together. that is the only way to make it truely "right on". best of luck......69L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 07-26-2005, 10:44 AM   #5
Jefe
Jefe's Avatar
I'm going to balance the engine with the plate bolted to it. I think thats the idea of the plate, makes a 350 flywheel or flexplate into a 400 flywheel or flexplate sort-a-speak. Just wondering if anyone has used one before. Thanks for the info!
Douglas.
