punch holes in dash for A/C?
HI All!
Any Ideas on cutting, punching the 2 round,oval holes and rectangle hole in the dash when adding/installing the A/C vents? thought I would ask before I tackle it. The Air is working good, now just need to finish the vents. This is the factory setup I took off a 72 with A/C and adding it to a 72 without a/c. I made the templates from an orig. dash, I marked them on my dash, now just need to cut, punch them out. Jeff Smith Pensacola, FL |
member #16
![]() Join Date: Dec 1999
I used a die grinder with a cutoff wheel and dremel tool to cut the center vent and then a hole saw and a rotary file in die grinder for side vents. Took about 20 min. per hole. Tape around the holes with masking tape to keep from chipping paint. Also there isnt too much leeway on the side vents for width. Check often when close to size. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
If you have the templates to work from than that's half the battle. I basically eyeballed it... taped it, penciled the outline and used a body saw to cut them out. It easily turned the curve for the outside vent holes. The side holes appear to be oval, but they're actually a circle if you look at them straight on. I drilled four holes to radius the corners of the center vent and then a few more to get the body saw started. Used a die grinder and hand file to finish them up. John is right... tape it up to avoid chipping, test fit often and remember you can always make them bigger if you have to.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
blood type; Retumbo
what they said except when done send me the templates
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#5 | |
graphic designer
Oilfield Trash
mvpco, Did you use a factory A/C Box? If you did, how did you make the firewal work, in respect to the different hole sizes and locations?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Chance
![]() Join Date: Sep 2001
templates
That would be great if you had some templates to distribute. I need to get the A/C holes cut before it goes to paint. Just to make sure "ever stuff" works.
Chance
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
72GMC51
template a/c vent
I have the templates from old air products will post when I get home from work.
JC
72 GMC 2wd 1/2 long 350 700r4 A/C PS PB 4:10. Are they ever really finished ![]() |
Chance
Templates
Great!! When they are posted are they going to be to correct size? Thanks!!!!
Chance
Java Mechanic
I recently saw a number of ac dashes for sale (cheap) on the parts board. That miight be a way to go also.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
55454
The easiest way without cutting up another dash for templates which I have done, cargo light also ( STP has the templates they go back and fourth between us) is take masking tape go over the hole on an a/c dash cut the middle out and put it on the other dash and mark it. Someone, someone knows has to have an a/c dash. If not pm me and I will cut a pattern and sent it on saran wrap. Postage due of course.
Tommy |
'69 Step
I used a hole saw, cut one size smaller than actual hole needed, then dremeled it to size. Tape is a must, along with checking often..
#13 |
Chance
hole saw??
What is a whole saw? Is it that cylinder which was around the perimeter of the cylinder?
Chance
#14 | |
72GMC51
I emailed them to another member and he said they worked great, if you would like I can do the same for you or will snail mail them to you if you want.
that goes for anyone that wants them. Thanks JC Quote:
#15 |
cut and file
That's what I did. I used a rotary file for my cordless drill.
Work slowly so you don't cut too much. The holes don't have to be perfect just enough to insert the AC grilles. |
#16 |
![]() Join Date: Apr 2005
Hey Jeff,
Where do you hang out? I'm up in Pace, got a 69 Suburban I "playing" with. Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#17 |
That looks like a nice spot to hide some speakers actually, Hmmmmmmm.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
#18 | |
Born a Chevy Man
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#19 |
i am putting a "vintage air" in mimy 71 c-10, i bought the factory style ac side vents from them , but all they sent me for a cut out pattern is for their small ac vents
![]() ![]() thanks in advance.
TIM ![]() '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
#20 |
Here is my copy of the ac vent templates.
'69 C/10 Short Wide 350/400/AC/Tilt/Tach |
#21 | |
Yep!!
2014 GMC Yukon XL (Wifey's) 2004 Chevy Silverado Crew Cab Z71 |
#22 | |
Great! I am off Olive Road, between 9th Ave and davis Hwy. 3519 Gatewood Drive Pensacola, FL 32514 475-5030 324-1713 Cell if you want to look it up on Yahoo Maps or Map quest. I have some extra stuff (power steering pumps, radio etc) if you need Do you have A/C in yours?? I would like to look at it!!!!!1 Jeff Last edited by mvpco; 07-29-2005 at 03:33 PM. |
#23 |
Duct Hose for left and right vents A/C
HI All!
Ok.... I tried to hook up the damn duct/hose to the side vents and just about /8 to 1/4 to small (I odered a set off Ebay some time ago). Question: is there a special type duck for the left and right side vents on the dash? and who has them and phone number and part number please. They set I bought are just like the defrost hose but alittle bigger. I tried locally but only sizes are 2 1/2 and 3 inch, I measured miy vent where it hooks up and it is 2 3/4 inch doh!!!! Jeff Smith Pensacola, FL |
#24 | |
'69 Step
#25 |
duct hose to a/c vents?
HI All!
I ordered a complete duct hose A/C & defroster set and all fits fine except for the 2 that go to the 2 side A/C vents. Just to damn small(hose/duct) I measure about 2 3/4 inches and the duct that comes with the kit is just over 2 1/2 inches. any ideas on this or where to get the correct hoses/ducts for the A/C vents? Jeff Smith Pensacola, FL 850-475-5030 |
