Old 07-26-2005, 09:02 AM   #1
71400lb
71400lb
Is my temperature gauge broke?
I have a 71 c/20 with a rebuilt 400 small block Chevy 4 bolt main. I was told when I bought the truck, that the motor came out of a 72 Nova, but apparently 72 Nova's never came with 400 SBC's.
Anyway, the guy I bought it from said he removed the thermostat and put in what he called a "restrictor plate" instead! So it has no thermostat.
The truck has been fine for the past year, but today I noticed my temperature gauge was all the way over to the "C" on the left. I drove all the way to work(18 miles) at 79 degrees outside, and the gauge never moved!
When I shut the truck off at work, I noticed when I insert and turn the key clockwise just before the "start" position, the gauge needle moves quickly all the way to the left, like it should,,,so power IS getting to it...and when the truck is started the needle just stays at "C".
Should I be concerned? What's your theory?
71400LB
1971 3/4 Ton 2wd
400 SBC/4 bbl Quadrajet
3.73 Open
71400lb is offline   Reply With Quote
Old 07-26-2005, 09:39 AM   #2
67chevemall
67chevemall's Avatar
sounds like the sensor.
There was just a post on this, I'll see if I can find it.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-26-2005, 09:42 AM   #3
71400lb
71400lb
much appreciated,
Old 07-26-2005, 09:50 AM   #4
67chevemall
http://67-72chevytrucks.com/vboard/s....php3?t=165544
I can't get mine to move at all. I hope we can solve the problem.
Old 07-26-2005, 09:51 AM   #5
67chevemall
A quick test you can do to see if the gauge and wiring are working is to turn you key in the "on" position, disconnect the green wire from the temperature sender, and short it against the housing of the temperature sender. The gauge needle should go way up to the H position. If it does, then chances are that your gauge and wiring are fine.
Old 07-27-2005, 11:30 AM   #6
71400lb
71400lb
Okay, dumb question, but where is the temperature sensor and what does it look like? Can I pick one up at AutoZone or is it a special order thing?
Thanks,
71400LB
Old 07-27-2005, 11:53 AM   #7
A.P.
Black 72 Chevy
A.P.'s Avatar
On the 350 engine the temperature sensor is located on the driver side. And its between the 2 front spark plugs.
A.P. is offline   Reply With Quote
Old 07-27-2005, 01:26 PM   #8
71400lb
71400lb
Thank you for the quick response and picture too!
Well, mine is a 400 small block Chevy, but it's probably the same thing as a 350 anyway...I will check it asap...thanks again.
71400LB
Old 07-27-2005, 02:38 PM   #9
71400lb
71400lb
I FIXED IT!
Thanks all for your input, the picture was especially helpful. I found the sensor and sure enough the green wire going to it had broken completely off! So on my lunch hour, I spliced in a new piece of wire and black-taped it all snug and VOILA, the temp gauge works perfectly again!
Thanks again,
71400LB
Old 07-27-2005, 02:49 PM   #10
panhandler62
Java Mechanic
panhandler62's Avatar
I see you have one of those custom single exhaust port 350s.. wink
Keith
11 Lincoln MKT -- Momma's wagon
13 G37xS -- middle age crazy car
68 C20 Fleetside -- RIP
Decorating the whole town up at a cost of $27 ....
panhandler62 is offline   Reply With Quote
Old 07-27-2005, 04:09 PM   #11
Mad Dog
Mad Dog's Avatar
It took me a minute to figure out the picture.......God, I'm dumb sometimes
72 C10 longbed 5/7 drop, Telstars, 350/th400(for now)
69 Chevelle SS396 (427/th400)
88 K5 on 35's (355/700R4/208)
Mad Dog is offline   Reply With Quote
Old 07-27-2005, 05:58 PM   #12
byrd
Union Electrician
byrd's Avatar
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 07-28-2005, 10:18 AM   #13
A.P.
Black 72 Chevy
A.P.'s Avatar
Hahahahahaaaa...
panhandler62 the way gas prices are going, I can afford to run one piston.
