07-26-2005, 02:11 PM | #1 |
The Higher The Better
Frame/Axle painting start
I got the first part of my frame/axle painted and I think it turned out well. I used the Eastwood rust encapsulator and chassiss black. It seems to me that it is going to work great. I used spray in bedliner about a year ago and that was a terrible idea. What didn't crack off I had to scrape off and wire wheel all of this but I think it will be worth it. Has anyone else used this stuff?
07-26-2005, 02:14 PM | #2 |
Some more
07-26-2005, 04:16 PM | #3 |
*Proud Member*
i haven't used it yet, but was considering on using it to do some touchup! looking real nice! did you spray it? brush it?
nice work! |
07-26-2005, 04:25 PM | #4 |
did you sand or blast the fram or did you just hand sand the big stuff and start painting b/c i am doing a full frame restore and i am at that point of what to do i want to buy a blasting box for the small stuff and maybe just hand sand and paint the frame with a rust preventer of some sort any info you may have would be appreciated
square body trucks an addiction or an investment either way they consume all my extra time and money |
07-26-2005, 06:47 PM | #5 |
Chevys Kick A$$
Looking good, ^ any more info on what 86 GMG asked would be appreciated.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER I would rather push a Chevy then drive a ford!!
07-27-2005, 06:46 AM | #6 |
First I scraped off what I could with a putty knife. Then I soaked old rags in paint thinner and wiped it down. What that didn't get I wire wheeled. Then I sanded and wiped it down with thinner again. I brushed the rust encapsulator on. You have to make sure you get everything off the frame before putting on the rust enc. You will really be able to tell if you don't and then you will have to wait till it dries so you can sand it and so it over. Hope this helps. I started the second part of my frame last night. I am going from the front cab mount to the front rear spring hanger. Let me know how yours goes
07-27-2005, 08:55 AM | #7 |
thanks for the info i am planning to start maybe in a week or two
