07-26-2005, 10:44 PM | #1 |
Is this a truck vin???
I just picked up a block with this info ....
...cast # 3935440 ...which is a bbc, 4-bolt main block ...with this vin stamped above the oil filter ...."18B20XXXX" ...could this be a motor that came in a chevy truck ......and would the truck have been built in late August or Sept., 1968 ???? .. ....thanks, |
07-27-2005, 05:44 AM | #2 |
According to Mortec it is a 68-69 BBC, 2 or 4 bolt main. The area above the filter is an alternate location for a VIN number.
Is there a suffix number on the right front pad. That may tell you more information. Jim http://www.mortec.com/bbc.htm |
07-27-2005, 06:01 AM | #3 |
yes...the front pad says "T0824KG"....
07-27-2005, 07:24 AM | #4 |
This is what nastyz28.com has to say:
1969 KG Chevelle 396 Mt alum hd
Tim Last edited by Blazer1970; 07-27-2005 at 07:24 AM. |
07-29-2005, 12:42 PM | #5 |
If a 1968 chevy truck was built the last week of August, 1968...
....What would the vin range be????? |
07-29-2005, 12:44 PM | #6 |
...oh, ...and it was built in the Baltimore plant....late August , 1968????
...What would the vin range be??? |
