Old 07-27-2005, 08:54 AM   #1
lowrider79
Neutral Safety Switch
I am nearing the end of the build on my 1969 SB Stepside and need help with a neutral safety switch. My truck originally had a 4 speed but now has a 700 R4. The problem is that I am using a wiring harness out of a diffrent truck a 1972 that had an automatic. The steering wheel I am using is out of my 1969 standard transmission. Does anyone have a wiring diagram for the neutral safety switch circuit?
lowrider79 is offline   Reply With Quote
Old 07-27-2005, 09:22 AM   #2
72MARIO
72MARIO's Avatar
It's the purple wire going out of the fuse block to the fire wall plug. The switch just splices that wire. You will have to extend the stock one so it reaches.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 07-27-2005, 01:18 PM   #3
lowrider79
