Old 07-27-2005, 06:47 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Which Cruise Control System to use?
I want to put cruise into my 72, I have a servo and a switch from an 84 truck but i would need to find the wiring diagram to make it work(does anyone have a diagram?) or should i go with aftermarket? If so who makes one?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 07-27-2005, 08:57 PM   #2
pjmoreland
pjmoreland's Avatar
http://67-72chevytrucks.com/vboard/s....php3?t=151318
pjmoreland is offline   Reply With Quote
Old 07-27-2005, 09:34 PM   #3
KEH
Better late than never
KEH's Avatar
I have installed the Audiovox cruise control but have not been able to get it to work.
1970 C/10 SWB Stepside
KEH is offline   Reply With Quote
Old 07-27-2005, 09:47 PM   #4
Blue85
Oilfield Trash
Blue85's Avatar
The 84 setup that I have is a lot different, due to the fact the servo mounts on the fender and a cable runs to the carb, it has 5 wire hookups on it, i can probably make it work if i can find out what each of the wires is for. do you have any pics of your braket you made for vacum kill swicth?
87 Chev 3+3 4x4
Old 07-28-2005, 08:58 PM   #5
pjmoreland
pjmoreland's Avatar
I wish I had taken a picture of the kill switch bracket before I mounted it. It's not visible without a little disassembly. It would be difficult to reproduce unless you have access to a milling machine, as it was milled out of a block of aluminum. You could probably make a bracket out of a piece of 3/4 x 3/4 angle. You'd have to find a couple of nuts to hold the switch onto the bracket though. I put threads in my bracket, and slotted it so that the bracket pinched down on the switch to keep it in place. You could probably use the stamped sheet metal nuts from a stock brake light switch.
