Need help on rear axle play..
Guys- my pass. side rear axle has 1/4" play in it. In and out, not up and down. It clunks when truck is pushed back and forth. I replaced the bearing and seal with a NAPA oversize bearing. That didn't help. The C-clip was'nt worn down that much! They're only about 1/4" to begin with. Did my axle grow longer or what!? This clunk has been there several years. I think it's grown a little over the years, but not much. Any ideas?
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
does your pickup have the original axles in it or have they been changed over to 5 bolt?
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick" ~72 chev swb w/68 front clip "GM Millenium corvette yellow" I use and accept Paypal |
Since the carrier pin stops the travel inward and the slack is on one side, my thought would be that the axle gear has too much slack in it. It can be shimmed if that is the problem. It might be worth checking.
Jim |
Its the original 6-lug axle, rear end, etc. By shimming, do you mean those dished washers on the little side gear?
never mind. I just found out the play comes out when you put the drum back on and tighten the wheel on. Duh! And the idiot of the week award goes to.... I think the clunk seems to come from the panhard bar, even though I put a poly bushing in it 5 yrs. ago.
![]() Join Date: Sep 2001
LOL
Oh well, learning is fun.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
