Old 06-25-2002, 01:31 PM   #1
one legged lance
Junior Member
where do you get your frt end rebuild parts?
I need to rebuid my front end and wondering where I should gofor parts.
I ordered a drop get from Early Classics but I still need ball joints & control arm bushings.
I live in Phx so any thoughts?????
1 Leg Lance
one legged lance is offline   Reply With Quote
Old 06-25-2002, 01:43 PM   #2
Low69CST
I got mine at Rogers Auto Parts in Frankfort Kentucky. I think Napa sells Moog parts. I would try them. No shipping from napa!
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 06-25-2002, 01:57 PM   #3
JJR
JJR's Avatar
I got mine from a local parts store. Most local parts stores will carry Moog or TRW parts for a decent price.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
Old 06-25-2002, 02:10 PM   #4
Woody
Got Mine a few years ago from MOTHERTRUCKER. Price was 1/2 of what NAPA wanted for same brand-MOOG. Thanks Ed!
Woody is offline   Reply With Quote
Old 06-25-2002, 02:22 PM   #5
69&72Bowties
I bought all of mine from PST. They have good products and good prices...
www.pst.com
Bryan@ideamill.net
71 Chevy Custom 20 Suburban
69 Chevy Camaro
69&72Bowties is offline   Reply With Quote
Old 06-25-2002, 05:33 PM   #6
junkyardjohn
junkyardjohn's Avatar
I RECENTLY REBUILT THE FRONTEND ON ONE OF MY 72 1/2 TON 2WDs, & FOUND ONE HELLAVA DIFFERENCE IN PRICE FOR THE SAME PARTS, BY THE SAME MANUFACTURER. AN AUTOZONE JUST OPENED UP IN MY NEIGHBORHOOD, & I DON'T KNOW IF THEY'RE PRICES ARE TEMPORARILY ARTIFICIALLY LOW, OR WHAT. FOR INSTANCE -- THERE LOWER CONTROL ARM SHAFT KIT - MCQUAY-NORRIS PT.#FA1142 WAS $31.99 WHILE KRAGEN AUTO PARTS PRICE WAS $63.98 FOR THE EXACT SAME PART. KRAGEN HAS A DEAL WHERE THEY WILL MATCH ANY COMPETITORS PRICE & TAKE AN ADDITIONAL 5% OFF. I WOUND UP BUYING ALL THE PARTS FROM THEM, BUT THEY LOWERED THE PRICE ALMOST $90 (FOR TWO)ON THE LOWER CONTROL ARM SHAFT KITS ALONE. SO FOR GODS SAKE, COMPARE SOME PRICES & YOU'LL BE AMAZED. I WAS.
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 06-25-2002, 05:43 PM   #7
COBALT
COBALT's Avatar
I've been doing some looking recently, and I think PST has what I need. NAPA does too, but it was a pain to try and put together everything I needed (I have a lot to do), where PST had a kit already together. Finally, when you add up all of the cost it's pretty comparable. They also do regular rubber bushings and polygraphite as well (higher price). Use the web site and request a catalog.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-25-2002, 06:16 PM   #8
junkyardjohn
Thumbs up
I COMPLETELY REPLACED EVERYTHING -- 2 UPPER BALL JOINTS,2 LOWER BALL JOINTS, 2 UPPER CONTROL ARM SHAFT KITS,2 LOWER C.A. SHAFT KITS, 2 INNER TIE ROD ENDS,2 OUTER TIE ROD ENDS. 2 TIE ROD ADJUSTING SLEEVES, & ONE IDLER ARM, & 2 EACH INNER & OUTER WHEEL BEARINGS. I THINK THATS ALL??
junkyardjohn
DON'T RENT U-HAUL
Old 06-25-2002, 07:05 PM   #9
COBALT
COBALT's Avatar
First question out of NAPA's mouth when I asked for these parts was "What's the diameter of your sway bar?"
Seattle, WA.
