No,I DON'T have Tourett's
Front Sway Bar '72 K5 4WD
I am looking to install a front sway bar, and eventually the rear. Where did you get yours and how much was it?
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
"Ochre Ogre"
I just picked up a 77 K1500 suburban and it has the front sway bar. Looks to be a direct swap.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
I converted about the same vintage ('77) swaybar to work on my '71. I had to fabricate some mounts (see pics). They bolt to the front crossmember and I only had to drill three holes total to mount it up. I used the rather large existing holes as the primary mounting points.
With a modest (<4") lift in the front, and ORD quick disconnects, it sits in there perfectly. I've got some soft 9-leaf Alcan springs in the front, and with the swaybar, it has a really nice ride and decent handling for what it is... It's been a long time since I have driven without, but way nicer than what I recall.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
I used the u-bolt plates off of the later model truck. The ORD disconnects cure any binding that might have happened due to the imperfect geometry involved. Here's a couple more...
nice job, 71
