Just got the sound deadoning pads that have a black tar like substance on one side and white foam padding on the other. My old ones were so mangled when I took them out that I didnt notice which side went against the cab floor. Anybody know the deal with these things?
The foam side was up on mine, that way from factory.
72 Cheyenne Stepside 357/TH350 3.07 Posi 379HP@5500 412FT#@4000 96 1500 Work Truck 88 Chevy Van 3/4 97 Tahoe 8.5 Lift (Sons) 00 1500 LT 4x4 (Sons) 98 Ford Cobra (Wifes Car) |
The foam was down on mine. I just ripped it out today. I found lots of new rust i didn't know about and 63 cents
now thats a true COON DOG
![]() Join Date: Nov 2000
I'm almost 100% sure that it's black side down! althought I don't really think it would make much of a difference.
LOL chevypunk
current project 67 ![]() 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's ( was crushed by a tree, bed sold, motor pulled) ![]() 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE work in progress, soon to have 250-I6 with a 3-speed on the tree 4.11's and posi ( currently sitting in back yard tarped awaiting time, $$$, and lots of love!) 67 1 TON- work truck 396 sm 420 4-speed, flat bed 4.57 gears "big red" (my first landscape truck, very rusty and crusty! but still gets the job done when needed!) |
just took them out yesterday the white foamy piece goes against the paint and the black will be on the top .the black should have a water proof paper and the paper side goes down.
Well, thats two votes for foam down and two for foam up. LOL. So who is going to be the tie breaker?
white side down.take it to the bank
Gasser
I took mine out Saturday. I didn't see any white
![]() Stepside
:thud 70 sstep tubbed, Muncie, double hump, snowflake, |
Most I have seen a have the tar side down and the foam up.
But as many I have seen the otherway as well. The tar side was supposed to stick to the floor boards to stop the sonic resonance that the truck has from the engine running. There are a ton of newer cars/truck that have just got the tar on the boards and then have jude padding under the carpet. The jude acts to insulate and keep heat/cold out as well as give the carpet a softer feel . The foam side was supposed to hold the jude material that goes just under the carpet from shifting. They use a spray adheasive to take the place of the foam holding the jude in most newer cars Also the tar acts kinda like a under coating to help stop rust from forming. The foam would hold mosture if it were facing the floor and it couldent evaporate if the tar were on top ....Kinda like if you put a plastic cover over a bucket of water (if mosture ever got in there).
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
the tar is for sound deadening and vibration deadening...it goes against the floor pans
the closed cell white foam is for temperature insulation...it goes directly on top of the tar paper stuff. carpet or rubber floor mat goes on top of this. |
send me your e-mail address and i will send you pictures.would post them but don't know how.i have a 47,000 mile truck that has never been touched.
white foam down on mine
70 short,step on a 72 frame. |
#13 |
Ok, i will say it again i bought my truck new the black tar side is down the foam side is up. one reason is so the carpet or rubber mat does not stick to the tar. As sooner or later u will have to replace the carpet or pad. u do not have to try to pry them apart after ten years or so. Also the foam helps stop the dirt from building up in the tar, if u lift up your carpet every so often u can vacuum the dirt from the top of the pad. If u have the tar side up the dirt will be stuck to it.
72 Cheyenne Stepside 357/TH350 3.07 Posi 379HP@5500 412FT#@4000 96 1500 Work Truck 88 Chevy Van 3/4 97 Tahoe 8.5 Lift (Sons) 00 1500 LT 4x4 (Sons) 98 Ford Cobra (Wifes Car) Last edited by blue72stepside; 06-25-2002 at 10:55 PM. |
#14 |
maybe it depends ,all my trucks have rubber mats but all of mine have the white foam down first,and i also notice that the black tar piece has a water proof coating to keep it from sticking to the mat.
#15 |
snow man - bpogs@alaska.net is my home email.. Any pics would be great. Sounds like everybody has it different with the tar and foam deal. Maybe they put the foam down with the rubber mats and the foam up with the carpet. Who knows. I'm gonna find the right answer on this even if I have to find somebody at GM Corp to answer it.
#16 |
All mine are (starting at paint)tar,foam,carpet or mat.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter ![]() Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
#17 |
black and white
i have five pictures i will post and the pictures are from an original truck that has never been touched. it was a one owner with 47,000 actual miles.
#18 |
black and white
1969 we just took the tar paper off the top
#19 |
1970
next pic
#20 |
next pic
next pic
#21 |
last pic
last pic
#22 |
Formerly yellow72custom
Mine was tar down, but i took it out when i removed my floor mat
to see how much rust i had to deal with. The tar was pretty moist, i kinda think it held in moisture and made my floor rust out ![]() i put new carpet in it, i will either coat the floor with POR 15, or undercoating to protect the new sheetmetal.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
#23 |
Southern but in Ohio!!!!
In all the trucks I had the foam has been up tar down...... the only wone that wasnt that way had a rubber mat......
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79 1972 custom-10 half/ton longbed 1980 1/2 ton 4x4 all original 350/350/205 with air Eaton,Oh rebelryder@hotmail.com |
#24 |
man, this should have been a poll! All mine have been foam up.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
#25 |
Giddy up giddy up...
Black side up or down?
Oh, thought you were talking about pavement
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site... |
