07-31-2005, 10:44 AM | #1 |
AUSTIN TX
Question about my Starter
1st time in removing a starter and i need a little help. Is there any special way in removing and istalling it. I only saw two bolts at the bottom, is that the only two that I must remove so i can take it down. please let me know.
07-31-2005, 11:15 AM | #2 |
7000 #'s of american IRON
i believe thats how it was on our camaro..2 bolts should be it...might need to move the exhaust around a bit.
07-31-2005, 12:27 PM | #3 |
Yes its the 2 bolts that go into the block. Then on the soloniod there is 3 wires bolted to it that you must remove to get the starter out. And just for good measure since you said this is your first time takeing a starter out, Be sure to disconnect the battery. If you don't youll see a spark show within 6" of your face
86' C-10 Silverado 85' C4 Corvette When in doubt, BURN OUT!! |
07-31-2005, 12:46 PM | #4 |
Until Seventy Times Seven
... spark shower
Just a couple of other things... You may find it easier to disconnect the wires from the starter/solenoid terminal while the starter is mounted to the block, if you can get to them. You may also want to remove the bell housing cover to check the starter-to-flywheel clearance after you replace it. GM recommends 0.020 to 0.060. A standard paper clip works well as a gauge since it's about 0.035. Use shims if need be to obtain the proper clearance. It's not too bad of a job. Good luck.
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
07-31-2005, 01:34 PM | #5 |
AUSTIN TX
thanks a bunch guys, I appreciate all the help.
07-31-2005, 04:26 PM | #6 |
Its Magically Delicious
when putting the new starter back in .. use a floor jack to hold the starter up while you align it .. its alittle easier on the arms ... torque the bolts to about 25 ft-lbs
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
08-01-2005, 10:11 AM | #7 |
it maybe a little to late but before you leave the parts store have them check your new starter i have put new out of the box starters on before and they were bad they did work but not real well good luck and be careful
square body trucks an addiction or an investment either way they consume all my extra time and money |
