Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-31-2005, 12:31 PM   #1
Thiele
Need axles for 1962 half-ton C-10 Chevrolet truck
I have been trying for a week to find the right and left axles for my 1962 Chevrolet C-10 half-ton pickup. All 1962 half-ton C-10 engine sizes have the same axles. Current set has been damaged by worn axle bearings which wore a shallow, somewhat pitted groove into the shaft causing unaceptable noise. I have new bearings and seals, so all I need is a couple of good axles. The axles have 17 splines and are 30 1/8 inch long, button end to surface of flange, for the left axle, and 31 1/8 inch for the right axle. The flange has six tire studs. Any help would be greatly appreciated.
Thiele is offline   Reply With Quote
Old 07-31-2005, 01:56 PM   #2
64fleetside
Try Tom Myers, Miami, OK, 918-542-3871
64fleetside is offline   Reply With Quote
Old 07-31-2005, 02:05 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Any of the aftermarket axle companies will sell you a set of new ones. Strange comes to mind right off.
Old 08-01-2005, 09:46 AM   #4
64fleetside
Before '63 it was the Eaton rear, kinda of an oddball rear end. Brian
Old 08-02-2005, 11:23 AM   #5
Toddro
I've got an entire stock 62 rear end I'd be willing to sell you cheap... It's been down for about 5 years, but I don't remember and noise from the rear, so I'd bet it's OK... See my post under "Parting 62 project"
'70 Chevy C10 longbed: bone-stock!
'72 Lincoln Mark IV: yeah, I know it's a Ford, but it's cool! Soon to be smoothed and bagged...
Toddro is offline   Reply With Quote
Old 08-02-2005, 10:58 PM   #6
Thiele
Thanks to all who responded. I was able to get the axles by contacting Tom Myers.
Old 08-03-2005, 05:00 PM   #7
Thiele
Thanks for the offer. Since posting, I did find two axles. But if I need any more reae end parts parts, or the axles aren't good enough, I will get in touch with you.
