Old 07-31-2005, 06:13 PM   #1
dennislbrooks
dennislbrooks's Avatar
Factory 4 speeds and 4X4's -- PTO
If you have to ask what this is, you probably do not need it.
Turns freely, shifts in/out. Has forward, neutral, and reverse.
Arrow Gear Co. Model # SHC7 2B s/n 3070114
$100 and ride --if you are not pleased with it, you return it with the ride and I will refund the $100. About 30 to 35 lbs to zip 75022.
dennislbrooks is offline   Reply With Quote
Old 07-31-2005, 06:25 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Good Price
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 07-31-2005, 08:39 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
What tranny does it fit?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-31-2005, 08:54 PM   #4
dennislbrooks
If you have the 6 bolt PTO cover on your 4 speed or the 4x4 transfer case, there is a very good chance it will fit.
Old 07-31-2005, 09:02 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Unfortunately there where 3 different 4spds in the 4wds, and all three have different drive gears for the ptos. I have one in my garage now that is for a NP435, both my trucks have sm465s and it will not fit. And then theirs the sm420. The NP205 has a different drive gear also. let me research this.
Old 07-31-2005, 09:16 PM   #6
dennislbrooks
some info
23 teeth and the top gear tooth is approx 1.25" from the case mount
thanks
Old 08-01-2005, 07:02 AM   #7
So,do you have any idea what vehicle it was in?If you do,it would help narrow it down.I have a`72 that I want a pto for to mount to the NP205 t-case.Do you know if it was tranny or t-case mounted?
Old 08-01-2005, 12:51 PM   #8
dennislbrooks
Sorry, do not know if it was off a tranny or transfer case.
Old 08-05-2005, 10:02 AM   #9
dennislbrooks
more info
I found that Arrow Gear Co. was bought by Sack Bros Co in Nebraska. I was surprised but he told me that this Model SHC7 was made for the GM 420 4 speed trans from 48-67.
Old 08-05-2005, 07:15 PM   #10
There ya go!Unfortunately,now I know I can`t use it.But,at least there`ll be someone,now that you have the application nailed down.
