Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 07-31-2005, 06:16 PM   #1
dennislbrooks
dennislbrooks's Avatar
Factory 4 speeds and 4X4's -PTO
If you have to ask what this is, you probably do not need it.
Turns freely, shifts in/out. Has forward, neutral, and reverse.
Arrow Gear Co. Model # SHC7 2B s/n 3070114
$100 and ride --if you are not pleased with it, you return it with the ride and I will refund the $100. About 30 to 35 lbs to zip 75022.
dennislbrooks is offline   Reply With Quote
Old 07-31-2005, 06:41 PM   #2
ben@speedbarn
Done yet?
ben@speedbarn's Avatar
So what is it? PTO?
ben@speedbarn is offline   Reply With Quote
Old 07-31-2005, 11:39 PM   #3
1FaastC10
1FaastC10's Avatar
no, its a flux capacitor for you muffler bearings driven by the flow of decompressed air that flows through the canooginator valve, and lubricated with turn signal fluid.
1FaastC10 is offline   Reply With Quote
Old 08-01-2005, 12:04 AM   #4
Big Blue
Big Blue's Avatar
I thought thats what it was. I have that same thing in my golf cart. Hooked up to my thingamajewie on the down flow side. Cool device to switch with.
John
Big Blue ( John )
79 Chevy Pick up.....My Dailey
STILL Working on a frame up: 1987 Truck body on a 78 Blazer frame. Need cab blasted to start project. Got the cab BLASTED, Now Prep and Paint. Started to lay SOME BONDO and primer. Done, Ordering paint. Got paint, Stuff painted,Cab,Fenders, Hood more later. 9/7/2015 Got the clear coat on,now time to take one off. Started to put things back (What a nightmare) like the heating and AC stuff,inside wire harness, outside AC unit and booster, still more. May 2016, still working on the inside. Got duck work in,heating and AC. Radio (stock) in dash with after market in console later, Speaker are hooked up, Steering column is in. Getting ready to drop the cab onto the frame, Working on engine now since I have the room. Well here it is 2018, got the engine in and it runs, now I need to get the exhaust system in so I can adjust the lifters, to loud right now. Got the exhaust on now I am waiting for the break parts to come in.
Big Blue is offline   Reply With Quote
Old 08-01-2005, 05:04 AM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
LMAO
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
