Old 06-25-2002, 06:56 PM   #1
chevy2racr
So Many Ideas, So Little Money
chevy2racr's Avatar
question on buckets and blazer tops
ok, I was at a local guys "shop" and junk area today and there was one blazer tub that had been cut up(before he got it) and there were 2 buckets sitting there, black, with scroll pattern on them and the plastic backs, the backs were cracked and upolstry bad, dunno if the frames were straight or not, assume they are fac. I know there are pics around, but would someone make it easier on me and post a pic, dunno what year it was. dunno what he wants for them either, mgiht actually give them to me. then for the tops, what is a double wall top like? how to differentiate from a single? never really looked into this at all, there is a 2nd blazer and I'm gonna guess it was a double wall top, has some cracks, but a little bit of fiberglass work and I think it'd be good. heck, maybe get the whole blazer, dunno if its got a title, who knows how the rocker boxes are, if someone tells me how to examine them I will. ALSO he has a 70 or so GMC SWB 4X4 with 4 spd & 350 I think, the cab is fixable, front clip also prolly fixable. you know how it goes, he has a fleet bed for it, dunno what he'd be askin or anything is someone is interested..
Bryce
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors
71 C10 with 454
99 S-10 5.1L SBC 700R4
09 Malibu
Marshalltown, Iowa
chevy2racr is offline   Reply With Quote
Old 06-25-2002, 08:40 PM   #2
Mike C
Mike C's Avatar
The double wall tops have bolt holes underneath because the bolts go behind the side panels, through the top of the bedside and into the top. The single wall top has a metal "L" bracket made into the sides and the bolts go down and thread into the tops of the bedsides.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-25-2002, 11:00 PM   #3
Rod
Here ya go.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 06-25-2002, 11:04 PM   #4
chevy2racr
chevy2racr's Avatar
how bout a pic form the inside of a double wall?
71 C10 with 454
09 Malibu
Marshalltown, Iowa
Old 06-26-2002, 08:47 AM   #5
Mike C
Mike C's Avatar
Here's one while I was making my new side panels with my double wall top.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 06-26-2002, 01:40 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Kind of off topic, but does anyone know how to get the back door split in half so you can replace the metal parts inside? Mine are all rusted to H*ll and don't work. I've been trying to get it apart, but looks like a dremel is all thats going to work. Just thought I would split the door, then re-fiberglass it back together when its all replaced. Any ideas? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 06-26-2002, 11:37 PM   #7
70jimmy4x4
As for rocker boxes.... Look undeneath, directly behind rocker panels. There should be a flat surface about 14" wide runnung the full lengt of the rocker anels (and then some actually) the should be bolted to the front bottom of the rear wheel well and the back bottom of the front fender well ( or so I assume ! You couldn't tell by MINE !!!)
I would definetly be interested in the GMC (truck, Jimmy, parts...)
Whereabouts in Iowa....
Steve
'70 jimmy 4x4
'98 chevy zr2 (the misses' transpo)
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
70jimmy4x4 is offline   Reply With Quote
Old 06-27-2002, 05:23 PM   #8
70jimmy4x4
ttt
'70 jimmy 4x4
'65 stang
'81 shovelhead
'99 Dodge Ram 1500
