Old 07-31-2005, 08:30 PM   #1
hewl35
454 and TH400 in a 70 C/10 Questions
I asked this question in the drivetrain forum but thought I'd ask here also since I'm sure I'm not the only person that has done this swap. I have installed a 76 454 w/ TH400 in my 70 C/10. Now I have two questions:
Question #1 Heater Hose connections: Off the stock intake manifold I had a heater hose running to the radiator. But for the life of me I can't remember where the other heater hose connection is from. I thought it had to come from the water pump but their is no nipple. So where does the other connection come from. I can't use the big block radiator since it's too big. So I plan on using a stock style 4 core radiator.
Question #2 TH400 Kickdown switch.
I have the complete accelarator setup from the 76 except for the cable to the carb. How do you wire this into the 70 wiring harness?
hewl35 is offline   Reply With Quote
Old 08-01-2005, 12:53 AM   #2
jhow66
jhow66's Avatar
#1--remove plug right above lower hose ans install nipple there.
#2--install this switch( can still buy it at dealers) on your gas pedal bracket and run a wire from one post to switch on 12 volt source on fuse panel. Run a wire from other post to trans (on drivers side-one spade connector).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-01-2005, 05:06 PM   #3
hewl35
Thanks for the reply
Thanks for the reply!
Old 08-01-2005, 07:53 PM   #4
Long Roof
Old School, New Style
Long Roof's Avatar
Question: Did you use the BB engine mounts or SB?
Aaron
The Good:
- 72 GMC Jimmy 4x4 - 307 cid / 350 th
- 70 Chevy Suburban 1/2T 2wd - 454 cid /400 th
- 96 Chevy Impala SS - mainly stock
- 98 Chevy Tahoe LT 4x4 - all stock
The Bad:
- 86 Chevy Suburban 1/2T 4x4 - winter beater
The Ugly:
- 72 Chevy Suburban 1/2T 2wd - parts truck
Long Roof is offline   Reply With Quote
Old 08-02-2005, 08:10 AM   #5
hewl35
Aaron
Aaron,
I used bb frame stands from teeitoff and sb rubber mounts from the corner parts store. I looked in the FAQ's and saw a post from txfireman, i think that was his name.
Jeff
