Old 08-01-2005, 09:58 AM   #1
CST*TEN in Katy
Question What's this relay?
Could someone tell me what is the relay mounted on the passenger firewall? The pink (faded red?) wire goes thru the firewall all by itseld to the fusebox to a terminal labeled radio. These two wires with spade terminals do not have a home. I think one of them goes to the tranny backup plug. If memory serves, this pigtail has always dangled loose. I don't believe this to be a block heater, as this is a Texas truck.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest.
1989 Suburban
1971 Sleekcraft 455Olds Berkeley
1992 SC400 pimp ricer
CST*TEN in Katy is offline   Reply With Quote
Old 08-01-2005, 10:25 AM   #2
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
heater fan relay?
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
Old 08-01-2005, 10:47 AM   #3
Harold Shepard
TCS- TRANSMISSION Controlled SPARK relay, there might still be a funny looking vaccumn switch mounted to the intake still, with two vac. lines one to it from dist. and one from it to ported vac on the carb. This is a early emission attempt it is supposed to retard spark in high gear to reduce emissions. Most of the time the relay and a wire or two is all that is left. Hope this helps. Harold
Harold Shepard is offline   Reply With Quote
Old 08-01-2005, 11:08 AM   #4
CST*TEN in Katy
Thanks Harold. I tossed the factory manifold years ago and put on an Edelbrock Torker. That would explain the homeless wires and the 5 port vacuum tree I have.
1989 Suburban
