08-01-2005, 11:23 AM | #1 |
Fuel tank opinions need
I'm moving my fuel tank under the bed in my 70 SWB and looking for some opinions on the different choices of tanks. I would like to have a custom aluminum tank made but that's not in my budget. I've considered a fuel cell from Jegs or Summit but would require more fabication in the fuel filler hose since I want to put the filler behind the marker light. I'm leaning toward a new suburban tank. What are your opinions on the poly tank verses the steel tank.
TIA Mike
70 C/10 SWB Go ahead chance it........Columbus did!!! Steve (Chitlin) Bacon My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/ |
08-01-2005, 12:13 PM | #2 |
67 is sold
08-01-2005, 01:03 PM | #3 |
Its a Truck Thing......
I have the blazer/burb tank, and Im running the filler in the wheel well with some marine hose, should be ok.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
08-01-2005, 01:08 PM | #4 |
If you are putting it behind the marker a Blazer tank may be better than a Suburban. If I remeber right the Blazer exits a little further back. I am not positive if that's correct, it's been a while since I have seen a Suburban tank.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-01-2005, 01:40 PM | #5 |
yeller
Here is a link to the article I wrote about the fuel cell I put in my '73. I understand the year difference, but the idea is the same.
http://www.73-87.com/7387garage/chas...ellinstall.htm
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-01-2005, 02:07 PM | #6 |
I meant a blazer tank. My bad.
mike
08-01-2005, 02:32 PM | #7 |
Active Member
I am right in the middle of my conversion on my 72 SWB. Not fun for sure, I chose to cut my bed sill down 2 inches (good info on this in the FAQs) and will be popping the fuel filler up behind the wheelwell in the bed using a design I also saw on the board. My blazer tank was an LMC and it has a short goose neck, however I have seen others out there with a longer goose neck that appears would go up and over the frame rail a bit easier. So there is more than one style of Blazer tank out there, at least at the gooseneck. I was wondering how everyone out there is venting their Blazer tanks? Fuel fill is covered but what about the vent tube???
08-01-2005, 08:32 PM | #8 |
Good Question
Smitty
08-22-2005, 03:55 PM | #9 |
I am in a72 project and am using 79 pontiac bonniville tank/ with fill on side, also using 92 model sportside bed, using tank straps out of same car. fits on rear frame perfect and still will be able to use reciever hitch.
