Old 08-01-2005, 05:57 PM   #1
70GMCer
70GMCer's Avatar
Trans Kick Down Cable "Help"
I've changed my manual trans to a 350 turbo and now I need the kick down bracket to connect it to the intake manifold or carb. Does anyone have a picture of one? It would have to be for a 70 on back due to the rod linkage for the carb, not cable linkage. Where can I locate one?
thanks..........
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 08-02-2005, 06:05 AM   #2
JimKshortstep4x4
Talking
I used the bracket from a 71 on my 69 setup, (with an accelerator rod). The brackets are available from GMC Pauls.
I can take a pic later today if you like.
Jim
Old 08-02-2005, 07:11 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Steve, have you checked the local junkyards?. I'm pretty sure Pep Boys in White Marsh sells the chrome ones made by spectre for about $8.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-02-2005, 07:29 AM   #4
mrein3
mrein3's Avatar
When I had a 2bbl carb on my 4x4 I used the bracket off my 71 Monte that had a 2bbl carb and th350. (I swapped a 3-speed manual for the th350 in the truck).
When I put the 383 in with an Edelbrock carb, I bought Edelbrock's adjustable bracket.
I think any one will work as long as your donor has a similar carb. (4bbl truck = 4bbl donor, 2bbl truck = 2bbl donor)
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-02-2005, 08:11 AM   #5
tphsmith
still buypickupparts
tphsmith's Avatar
I have a stock bracket off a 350 motor its pretty ugly looking, I replaced it with one bought from advanced auto, if you cant get one you can have this one just i ask ya pay for the ride to you
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 08-02-2005, 04:58 PM   #6
70GMCer
70GMCer's Avatar
Need pics.......The ones I've seen at the local auto stores are for a cable accelerator and looks like the acc rod would get in the way.
70c10 (Jim), Haven't had any luck at the local yards. Again, was hoping to see a picture of one. If not, I might try the chrome one you talked about......
thanks all......
1997 GMC Sierra Ext
1965 Mustang
Old 08-02-2005, 05:09 PM   #7
70c10
67-72 Addict!
70c10's Avatar
Heres a pic of Cobalts truck. He used a Lokar bracket and Lokar cable.
Jim
Old 08-02-2005, 07:05 PM   #8
70GMCer
70GMCer's Avatar
thanks Jim, that helps.......
1997 GMC Sierra Ext
1965 Mustang
Old 08-02-2005, 08:07 PM   #9
JimKshortstep4x4
Talking
Here is a picture of my setup. The 71 cable bracket is just behind the vacuum line for the brake booster in the stock location.
Jim
Old 08-03-2005, 07:51 AM   #10
mrein3
mrein3's Avatar
Sorry the pictures are blurry. I don't know how to override the auto focus on my digital camera.
I used an Edelbrock piece to connect the throttle rod to the carb. I also used an Edelbrock kick down cable bracket.
Everything clears just fine.
'72 Malibu hard top
Center City, MN
