Old 08-01-2005, 07:40 PM   #1
Zonaman
Zonaman's Avatar
Evaporator Freeze Over?
On the way back up to Phoenix from Tucson I noticed my A/C airflow seemed restricted and the temp from the center vent was 57 F. After turning the unit off for a while, a lot of water drained off and things were OK again. Am I correct in deducing that my evaporator froze over? If yes, I have a control knob on the thermal switch on the evaporator. It was set low enough for air from the center vent to come out near freezing. I now have it set so that lowest air temp from center vent is 44 F. (at 90 F ambient, very humid) Is there a rule of thumb for lowest vent temp you can go and still avoid freeze over?
Thanks.
PS This is an Old Air Unit.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 08-02-2005, 12:54 AM   #2
sdkid
I would seem that you are on the right track. You may also know that a freon overcharge can cause this also. The thermal switch setting sounds best to me right now.
At least your getting a bump...
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
