08-01-2005, 08:04 PM | #1 |
Steel Cowl Scoop
I posted a while back looking for a company that sells steel cowl scoops. I am not looking for a hood, just the scoop. Somebody sent me the right link and I thought I had saved the URL but apparently I did not. Can any of you guys help me out with this one? Thanks in advance.
Larry |
08-01-2005, 08:25 PM | #2 |
I don't have your answer but this might help if the link was posted in your thread. Go to user CP on the right go to subscribed threads, this should show all the threads you have posted in if you are subscribed. It works even though there is no search function.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
08-01-2005, 08:43 PM | #3 |
Neonlarry,
Perfect!!! Thanks for the help. Larry |
08-01-2005, 09:47 PM | #4 |
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
08-02-2005, 09:00 AM | #5 |
one set closer
has anyone put one of these on a 67-72 truck. not a bad investment.
http://www.thespeedcenter.net/SpeedC...meFrameSet.htm Last edited by UP GRADE; 08-02-2005 at 09:02 AM. |
08-02-2005, 01:39 PM | #6 |
I put one on this hood. It's is a decent product all in all. Comes way long so you can put it as far front as you want. The cowl had a few waves in it that needed filler/glaze to smooth out (it was stamped like that), but overall I was happy with the result. I think it would go on a truck hood just fine.
A plasma cutter, and 1/2" air flanger made the job much easier. I cut the opening all the way around, so the scoop sat on about a 3/4" lip. Then flanged the lip all the way around so the flange on the scoop would sit down in it flush with the top surface. tack welded all the way around about a 1000 times. grind/fill/glaze/high build surfacer/paint
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear Last edited by 71cadc10; 08-02-2005 at 01:40 PM. |
08-02-2005, 02:24 PM | #7 |
Is that your Caddy? That's cool!!
08-02-2005, 03:59 PM | #8 | |
The LuvShack Garage
I agree, we need more pic's of that bad boy, looks like you drag her
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
