Old 08-01-2005, 09:29 PM   #1
hilljob26
hilljob26's Avatar
i need help w/ some pressure
i seem to be getting some unfortunite crankcase pressure,my engine is leaking a liitle bit of oil aound the dipstick tube,anybody have any ideas,it doesn't seem real bad,but a leak is a leak to me,i hate freakin oil leaks,its an after market aluminum stick,but i think the tube is just a chrome one,is that the problem ya think,any help would be appreciated
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 08-01-2005, 09:39 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do you have a PCV deal on one of the valve covers?
Old 08-01-2005, 09:41 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Check your pcv valve by pulling it out and shaking it lengthwise. If it doesn't rattle, it is gummed up and either needs cleaned or replaced.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 08-01-2005, 10:08 PM   #4
hilljob26
hilljob26's Avatar
i have 2 brand new aluminum breathers,any ideas
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 08-01-2005, 10:15 PM   #5
neonlarry
neonlarry's Avatar
Everbody I have ever heard that used a chrome dipstick tube complained that it leaked. Get a new factory tube.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 08-01-2005, 11:55 PM   #6
walker
walker's Avatar
Get a factory tube, or a new chrome one and sand the chrome off, them apply some goo (copper silicon, etc) and reinstall. Also, breathers do not eliminate the reason, or the need for a pcv valve. The pcv valve creates a slight negative pressure in the crankcase and thus, keeping the oil in the dipstick tube.
BTW I had the same trouble on a 350.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 08-02-2005, 12:02 AM   #7
Longhorn Man
Get rid of one of the breathers, and install a PCV set up plumbed to the carb or intake (perferably carb) and I agree on getting the chrome tube outa there too.....then you'll be set.
