Old 08-02-2005, 11:27 AM   #1
72swb4me
72swb4me's Avatar
What should I do about my '72 350
I spoke to a shop about reviving my '72 350. They said they would do a remanufactured longblock job for $850. Below is what that entails:
Bore and hone the cylinders
Grind & polish the crankshaft
High-performance 3 angle valve job
Resurface heads
New parts:
Rod, main, cam bearing
Camshaft
Front & rear main seal
Oil pump & lifters
Timing component set
Freeze plugs
Valve seals
Complete gasket set
I wanted to get some input from you guys/gals; do you think this is worth it? What have been your experiences with doing a rebuild on an old block? Thanks. Here is a picture of what the engine looks like right now.
72swb4me is offline   Reply With Quote
Old 08-02-2005, 11:58 AM   #2
truck69
I also have a 350 and one cyl is bad. I went to a local shop to see what they could do and their price was 1200. They said they warranty the work for 6 months or 5000 miles. Which ever comes first. SO I have been looking at rebuilt Chevy motors which is warranted for 3 years or 36,000 miles. Those are 1300 dollars. I have to save up a bit but thats what I am looking at.
Thanks. Truck69.
truck69 is offline   Reply With Quote
Old 08-02-2005, 01:01 PM   #3
CyberRanger
CyberRanger's Avatar
If I were goin' to redo my 350 in my 4x4 I'd put in a 400 crank & have it stroked to 383 for better low end torque as well as an aftermarket cam for better torque & mileage. It'd be a bit more expensive, but well worth the effort. My main beef w/ the factory engines has always been the terrible mileage & lack of low end torque.
Before they do any machine work I'd have the block checked for flaws or thin cylinder walls so you don't waste money on machining a bad block, crank or rods, unless they'll guarantee them w/o the check. It can really save you a lot of headaches.
'71 K20 Custom Deluxe - 1 owner - Original 350 & 4 spd, Rams horn dual exhaust, Centerforce clutch, K&N 4"x15", factory tow hooks, 4" Skyjacker Softride, Rancho RSX9000s, custom Firestone AirRide overloads, 36" 305/85R16 10ply Buckshot Mudders, 4.11 gears
CyberRanger is offline   Reply With Quote
Old 08-02-2005, 01:17 PM   #4
mrein3
mrein3's Avatar
I scanned your new parts list and didn't see new pistons on there.
I'm hoping the $850 includes new pistons (you need them if you bore the cylinders).
Right out of high school (late 80s) I bought a used 350 on a stand for $50. When I checked the holes they were still in spec. So I just honed them out, put in new rings, and still run that engine today. Talk about a cheap rebuild. Oh yeah. I had a shop go over the rods and I installed new bearings (of course).
If you need pistons, consider a 383. For the price of what you need to buy anyways, plus a crank, harmonic balancer, and flex plate, you have more torque and hp.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-02-2005, 01:44 PM   #5
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
Im getting pretty much the same thing done to my 350 but it ain't going to be that cheap, the guy said like $2500, but im getting new pistons and a crank
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 08-02-2005, 02:41 PM   #6
bowtie
bowtie's Avatar
Sounds about right, will you be going with a different cam?
~70 GMCprostreet swb 396/700r NOS 575 hp "the Brick"
~72 chev swb w/68 front clip "GM Millenium corvette yellow"
I use and accept Paypal
bowtie is offline   Reply With Quote
