Old 06-25-2002, 11:41 PM   #1
dion
72 Cheyenne
dion's Avatar
Front end question
Okay, I just put new shocks on today and the ride is much better but when I hit pot holes my truck still goes bam! What should I check? Everything looks pretty good, I'm stumped.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 06-25-2002, 11:52 PM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Do you have a sway bar? If the bushings get worn, they will cause a bang.
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 06-26-2002, 01:24 AM   #3
shadetree
shadetree's Avatar
Another thing to look @ is, the shock mounting studs. Where these bolt to the frame, the hole can wallow out, causing a bang when hitting a bump. good luck, steve
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 06-26-2002, 10:30 AM   #4
slam33
slam33's Avatar
check your upper and lower control arm shafts they get loose in the bushings and bang all around.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
